Buying a skunk2 intake manifold for my b16a
Old Nov 9, 2007 | 05:05 AM
crazyguy's Avatar
Default Buying a skunk2 intake manifold for my b16a
i have been looking and researching the intake manifold for my jdm obd1 b16a engine and i have my eye on skunk2 intake manifold. i have searched and it says stock throttle body "maybe" reused. can someone please confirm this if i need to get a skunk2 throttle body? also does skunk2 intake manifold come with intake gasket and throttle body gasket ? thanks.
P.S jdm b16a stock throtlle body is 65 mm if i remember correctly..is it really worth to buy a skunk2 68mm throttle body for like around $250 shipped?
Old Nov 9, 2007 | 05:10 AM
electron_si's Avatar
Default Re: Buying a skunk2 intake manifold for my b16a (crazyguy)
if the TB from the jdm b16 is the same as the usdm, you can re-use it. just buy a new throttle body gasket.
Old Nov 9, 2007 | 05:28 AM
instrument's Avatar
i thought the b16 manifold was pretty much the same as the skunk?
Old Nov 9, 2007 | 05:31 AM
crazyguy's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">i thought the b16 manifold was pretty much the same as the skunk?</TD></TR></TABLE>
i thought skunk2 intake manifold is close to ITR's
Old Nov 9, 2007 | 09:01 AM
crazyguy's Avatar
Default Re: (crazyguy)
any other opinions ? appreciate
Old Nov 9, 2007 | 09:05 AM
Bazza's Avatar
id do it right and buy the other tb for the extra money so you get the best out of your new intake manifold.
Old Nov 9, 2007 | 09:16 AM
Luserkid's Avatar
Default Re: (Bazza)
For the B16 you dont need a different Intake manifold unless your upping the compression or going with big cams (then you still need to up the compression) or a turbo setup. But to each their own. Yes your throttle body will bolt up to it as long as they are using the 4 bolt honda pattern. Where did you read the "maybe" from?
Old Nov 9, 2007 | 09:17 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Bazza)
Unless you have cams and/or head work the Skunk 2 manifold can actually make the engine LOSE critical low/mid horsepower and torque.
I'd keep the stock manifold until you get serious enough to toss in better cams, bigger TB, head work, etc. etc.
EDIT:
Look like Luser kid beat me by 1 minute!!!
Old Nov 9, 2007 | 09:26 AM
crazyguy's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote"> Where did you read the "maybe" from? </TD></TR></TABLE>
at skunk2 official web site and some ebay sellers ..
Old Nov 9, 2007 | 09:45 AM
Malakai's Avatar
im pretty sure the have it worded incorrectly. It should read it may be used. U can use the stock tb. Get the mani!
Old Nov 10, 2007 | 07:22 PM
crazyguy's Avatar
Default Re: (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure the have it worded incorrectly. It should read it may be used. U can use the stock tb. Get the mani!</TD></TR></TABLE>
yeah i ordered one..but anyone else has any opinion or experience on this intake manifold ?
Old Nov 10, 2007 | 07:28 PM
ltrkstr2k's Avatar
I had a S2 mani on my y8 with a Ls throttle body. the only thing that gave me problems was the fitting on the back of it for the coolant line. it was to close to another fitting and leaked. After taking it off 3 times i got it right and no leak. I also had a "plastic gasket" lol from Password JDM that helped w/ heat transfer. Just my .02 though.
Old Nov 10, 2007 | 09:18 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i ordered one..but anyone else has any opinion or experience on this intake manifold ?</TD></TR></TABLE>
PLEASE dyno the engine BEFORE you swap the manifold, and then dyno it afterwards.
Then my opinion about NOT buying it will make sense.
stutler_jdm
May 14, 2011 09:05 PM
nihad
Dec 22, 2006 08:47 PM
gringo-gsr-01
Sep 11, 2001 04:47 PM
