OMNI POWER Raw Aluminum Rear LCA Lower Control Arms (San Diego)
OMNI POWER REAR LOWER CONTROL ARMS FOR HONDA CIVIC OR INTEGRA
brand new never rolled on, in the original box. i installed them and removed them so they are flawless... this is what they look like. raw aluminum look im asking $150 picked up or $180 shipped
i have a sidekick celly, so for a faster respond hit me up on it... bump if you look... thanks...
aim: fievel1320
or
team1320presidente@tmail.com
Omni-Power lightweight rear lower control arms (RLCA's) manufactured in the USA using aerospace grade T6-6061 aluminum. We use 2 piece 100% pure polyurethane bushings that won’t squeak or crack like other poly bushings, which use fillers to cut costs. Each control arm is then hard anodized to eliminate corrosion and maintain a show quality look. Typical weight savings is approximately 4+ pounds depending on the vehicle model. All EG and DC RLCA's come standard with our exclusive 3 stage adjustable sway bar mounting and ABS line mounting for easy bolt on installation. Omni-Power RLCA's have more combined features than any other RLCA on the market and are also the highest quality rear LCA's available. These are a direct OEM replacement.
aim: fievel1320
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markH22eg6 »</TD></TR><TR><TD CLASS="quote">bump
good buy ... goos seller
i had the money
ill hit u up when i can get em if you still have em</TD></TR></TABLE>
i had the money
Untouchable13
Honda Civic (2001 - 2005)
Jul 12, 2009 10:36 PM
team1320_k26eg
Jul 16, 2008 09:05 AM
ImportAutoPerformance.com
72
Feb 19, 2007 02:06 PM
