lots of questions lol.
Old Nov 8, 2007 | 05:10 PM
Guiding my way back.'s Avatar
* B A N N E D *
Default lots of questions lol.
ok im getting a 95 2 door ex as a trade i want to put my b16a out of my crx in it.... will i need different mounts....
second question the 95 is a auto i want to go manual will i need the clutch pedal assmbley from the 95 or can i use the one in my crx....
third question i want to go obd1 can i use the d seires comp and dizzy on the b16a with the correct jumper harnesses...
im sorry for the dumb questions, help is appreciated.
thanks, kyle.
Old Nov 8, 2007 | 05:56 PM
* B A N N E D *
Default Re: lots of questions lol. (Guiding my way back.)
some help please if this is the wrong form can a mod please move, thanks.
Old Nov 8, 2007 | 06:27 PM
92BLKINTEGRA's Avatar
I don't think you will need different mounts but not 100% sure. not sure about the rest either.
Old Nov 9, 2007 | 05:22 AM
redboy183's Avatar
Default Re: (92BLKINTEGRA)
you need new mounts your ef mounts wont fit in a eg.....your tranny wont work either if its cable and eg's are hydro.....the eg is an automatic, you need a lottttt more than just the pedals.....conversion to obd 1 is needed regardless and no the d series parts wont work...soooo basically its not even worth it....get another ef and put the one six back in
Old Nov 9, 2007 | 07:17 AM
philkehn's Avatar
Okay where do i start lol...
You use the stock ex mounts in the civic for any b series motor swap... I WOULD SUGGEST using the ex pedals knowing the 95 ex has a hydro clutch setup and the crx has a cable clutch setup... You will need to get a HYDRO B SERIES tranny, unless you making custom brackets for a cable tranny to fit in and I would HIGHLY recommend using obd1 since thats the way the 95 ex's come and you WILL have to buy a new dizzy you need a obd1 dizzy and im 90 percent sure d series dizzy wont work on b series , IM <with fuel rail and injectors plugs (obd0 and obd1 injectors ARE different)
And yes you can use your d series computer just remember that computer isnt made for that engine... I have a friend the idiot put a gsr with a p28 (stock ex ecu)
Old Nov 9, 2007 | 06:16 PM
* B A N N E D *
Default Re: (philkehn)
ok thanks for the info guys.
Old Nov 9, 2007 | 06:40 PM
gunnerman's Avatar
Default Re: (Guiding my way back.)
u can use your cable tranny in your ex...there are conversion kits out there..
LSWagovan
Sep 6, 2010 01:40 AM
FastEg6
May 28, 2009 08:10 AM
skateroyals
Jul 16, 2008 09:56 AM
ohsnapzafingcu
Sep 12, 2005 09:19 PM
mckenzie
Mar 23, 2005 10:07 AM
