Extened wheel studs necessary
Old Nov 8, 2007 | 01:02 PM
TSAngry's Avatar
Default Extened wheel studs necessary
Extended wheel studs necessary with 15x7 +38 on a gsr?
Old Nov 8, 2007 | 01:51 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Extened wheel studs necessary (TSAngry)
Do you already know whether or not you need spacers, and if so how thick, or is that part of your question, too?
The normal rule of thumb regarding whether extended studs are necessary is that you need at least six full turns on the lug nuts, and if you don't have that, you need extended studs.
Old Nov 8, 2007 | 01:57 PM
TSAngry's Avatar
Default Re: Extened wheel studs necessary (nsxtasy)
No spacers needed.
6 full turns, thanks.
EJ2B16
Nov 25, 2011 09:05 AM
dc5RickK20
Jan 11, 2011 09:38 AM
Mikey3000
Jan 12, 2006 07:05 AM
2k.civic.si
Feb 22, 2005 07:49 PM
