Chipped Crank Pulley to replace Unorthodox one
Old Nov 8, 2007 | 12:08 PM
silverlude80's Avatar
Default Chipped Crank Pulley to replace Unorthodox one
I purchased a used stock crank pulley that was damaged in the mail. there are multiple chips on it and I'm wondering if this will effect anything in any way. I hear this is balanced and dampered, and could cause lots of damage using aftermarket parts ie.. unorthodox pulley. That is why I am changing it in the first place. I don't want to replace a bad part with another bad part.
2000 base prelude if thats important
Thanks
Old Nov 8, 2007 | 12:40 PM
mgags7's Avatar
Default Re: Chipped Crank Pulley to replace Unorthodox one (Acidcrakker)
Chips on the edge of the crank pulley are fine.
Modified by mgags7 at 12:09 AM 11/9/2007
Old Nov 8, 2007 | 01:45 PM
auto addict's Avatar
Default Re: Chipped Crank Pulley to replace Unorthodox one (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
Chips on the edge of the crank pulley are fine. </TD></TR></TABLE>
hmmmm i didn't know that....
Old Nov 8, 2007 | 06:07 PM
Default Re: Chipped Crank Pulley to replace Unorthodox one (auto addict)
What about throwing off the balance, and the weight? thats the whole reason I'm replacing the unorthodox one. The chips are pretty bad.
Old Nov 8, 2007 | 08:08 PM
mgags7's Avatar
Honda engines are internally balanced, so the crank pulley isn't going to do much to mess that up unless it weighs a serious amount.
The chips are outside of the harmonic system that the crank is in, they're behind the rubber ring, so any distortion they may cause, which would be negligible, would be soaked up by the rubber ring.
Chips in an unorthodox pulley would be a different story, because they don't contain a harmonic dampener, so possibly the harmonics generated by big chips could work their way into the bottom end.
cliffs: I'm right, and it's fine.
Old Apr 8, 2008 | 12:59 PM
ketchup's Avatar
Default sorry for bringing back an old post but...
What's so bad about the Unorthodox Racing Crank pulley?
Old Apr 9, 2008 | 11:03 AM
ketchup's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Honda engines are internally balanced, so the crank pulley isn't going to do much to mess that up unless it weighs a serious amount.
Chips in an unorthodox pulley would be a different story, because they don't contain a harmonic dampener, so possibly the harmonics generated by big chips could work their way into the bottom end. </TD></TR></TABLE>
So in short, just don't damage the unorthodox pulley because they aren't made with a damper.
Any other reason people are getting rid of their Unorthodox pulleys?
I need a single belt pulley that'll work for the H22A, that's why I'm curious. Only one avail is the unorthodox pulley.
DARKTEG_
Aug 13, 2006 03:15 PM
twistedbydezign
Sep 24, 2005 02:10 PM
asefi944
Apr 11, 2005 02:26 PM
airwalk07143
Sep 24, 2004 07:40 AM
Turbolude
Sep 12, 2001 05:53 PM
