Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 cr-v moan/groan from rear diff?
Old Nov 8, 2007 | 09:54 AM
crvan07's Avatar
Default 2007 cr-v moan/groan from rear diff?
my 07 cr-v having a problem
moan/groan during a sharp turn even on reverse bring it back to the dealer and said they did change the oil on rear diff per tsb 07-024 that should take care of it
now the cr-v is fine no moan/groan for now
there is a tsb 07-021 with vin# refering to it...my vin# is one of them the dealer didnt take care/fix it under this tsb...i ask them why they said that is the latest procedure - tsb 07-024...any ideas what to do
this is from honda service
replace the rear diff fluid
and burnish the rear diff clutches
Old Nov 8, 2007 | 06:41 PM
PnX-R's Avatar
Default Re: 2007 cr-v moan/groan from rear diff? (crvan07)
Hmm.. What's your VIN. Anyways. The difference between the two bulletins is that 07-021 pertains to the rear diff making noise while turning at low speeds in cold weather. SB 07-024 pertains to the rear diff just making noise while turning at low speeds in warm weather. As to whether it falls within the range or not, I don't think that's an issue. If your CRV makes noise while turning in cold weather, it'll make that noise as soon as they go out for another test drive. The one I dealt with made noise again right after I changed the fluid.
So in other words, if your CRV isn't making any more noise, it's ok. Either way you didn't have to pay for it.
Old Nov 9, 2007 | 06:13 AM
crvan07's Avatar
Default Re: 2007 cr-v moan/groan from rear diff? (PnX-R)
yes the V is now fine but i dont drive it much anyway...i got it a year now and its only 7200 miles the longest travel i made with the car is hershey park
i m just concerne why the dealer didnt consider tsb07-021 if my vin# false in the vin# range list on the same tsb
i read in other forum is that not all V is the same...one V has the same problem and same procedure done as per 07-024 in a month or so the problem came back and others is the same as what you have said...im just trying to avoid any hassle in keep coming back to the dealer with the same problem since i know what should have done in the first place
i didnt pay for anything cuz its under warantty
Old Nov 9, 2007 | 09:39 AM
PnX-R's Avatar
I was never a fan of that VIN range stuff. I've seen cars in and out of VIN ranges do exactly what the bulletins pertain to. Just because it's listed as falling into that range, doesn't mean it should fail. And as far as having trouble later down the road. If that happens, Honda can pull up the warranty history and see what's been done to the vehicle.
Old Nov 9, 2007 | 10:22 AM
crvan07's Avatar
for now im good...well if it problem occur again then i will be back to them and will ask if they can do 07-021 instead of just changing fluid/oil
im just hoping it wont happen this coming holiday...planning to drive to SC to visit some family
Old Nov 9, 2007 | 04:06 PM
diversegsr's Avatar
I'm assuming this is only pertaining to the AWD models
Old Nov 9, 2007 | 05:51 PM
josephcitr's Avatar
as long as they used daul pump ll fluid you should not have any more problems
crv s have made noise like this since they came out i dont understand how changing the fluid fixes it but it does every time i have worked for hondda for 8 years and chaging the fluid fixes it every time
Old Nov 15, 2007 | 02:55 PM
90CIVICSI's Avatar
Default Re: 2007 cr-v moan/groan from rear diff? (diversegsr)
yup. AWD Only.
Old Nov 21, 2007 | 05:43 AM
b18LS's Avatar
We had that problem with our '06. theres a bulletin out for the rear diff fluid. Apparently the newer crv's go through the old dual pump fluid in about 25% of the time of the old one. We had to have ours done at 20,000 kms. It was night and day with the new fluid.
Old Nov 24, 2007 | 08:47 AM
aries331's Avatar
Default Re: 2007 cr-v moan/groan from rear diff? (b18LS)
Where can I find these bulletins?
Old Nov 26, 2007 | 02:02 PM
b18LS's Avatar
Default Re: 2007 cr-v moan/groan from rear diff? (aries331)
check the honda usa website, not sure if theyd be on there.
Old Nov 28, 2007 | 07:55 AM
crvan07's Avatar
check on this site hondasuv.com and crvownersclub.com
Old Nov 30, 2007 | 06:36 AM
ChickenH's Avatar
They changed the bullitin in the last few months for the crvs VIN- thru Vin- making noise in the rear diff remove dual pump 1 replace with dual pump 2.
For a few weeks some models said replace diff. before they came out with dual pump 2 . I sold 2 diffs they had to send from japan before they were backordered . the dual pump 2 seems to fix the noises.
Asankaupe
Suspension & Brakes
May 10, 2017 06:21 PM
trappersmom73
Honda CR-V & Element
Jan 6, 2011 08:13 PM
stephen_civic98
Mar 26, 2007 05:11 PM
hdawg06
Nov 30, 2006 08:01 PM
Project SSAP1
Honda S2000
Jul 8, 2004 07:17 PM
