need help....h22a.....from wat vehicle...
i need hellp with identifying the engine h22a....its jdm but from what vehicle.....i look it up and says prelude sir 220hp....is that true.....????
got a problem w/ the engine swap also...the fuel rail is opposite of what i have rite now for the 94 prelude i think usdm....the fuel line from the regulator is too short...now do i have to swap out the fuel rail injectors and all that to compensate because honda doesn't have a long one for it...and i can't cut and tape them together......need help asap.....engine gets drop back in 2day....and also the distributor....since its jdm...the distributor with have a built-in coil pack.....usdm doesn't have that..they have the coil pack....would it be a direct fit if i buy a usdm distributor??? let me know asap..waiting for answers and help.....thank u
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: »</TD></TR><TR><TD CLASS="quote">Dizzy=Distributor
H23 dizzy has more or less wires.....thats all I know.
I got an H23 accidently....it doesn't work.
H23a1 distributor works on H22's. And when doing the swap, re-use the H23 wiring harness, the distributor and external coil should plug back in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">
Was that my problem then.....I was trying to use the H23a1 dizz with a H22 harness? I just remember looking at it and thinking....Um no! Bastids in PA don't know the diff between h23 and h22?!.....
