B-Series Parts
no it wont. but gsr will fit b16 and type r. and visa versa. non vtec with non vtec bseries nad vtec to vtec bseries. thats goes for the cams shafts. the cam gears tho yes u can fit them. and other parts u can use as well with lil to none modification depending on what it is your asking. ie: type r/gsr/b16 pistons on ls rods
No and yes. B16 and GSR items are mostly interchangable...however the intake manifolds, oil pans, and a couple other items are not. You cannot drop GSR cams in your LS and magically have vtec (which is kinda what I read in your post). The heads are not the same, rocker systems are completely different, ls doesnt have the capability to run vtec....period. Most headers will cross from any b-series engine though, as well as transmissions, clutches, fuel injectors, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">No and yes. B16 and GSR items are mostly interchangable...however the intake manifolds, oil pans, and a couple other items are not. You cannot drop GSR cams in your LS and magically have vtec (which is kinda what I read in your post). The heads are not the same, rocker systems are completely different, ls doesnt have the capability to run vtec....period. Most headers will cross from any b-series engine though, as well as transmissions, clutches, fuel injectors, etc. </TD></TR></TABLE>
b16 headers will not fit on an ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k624ash »</TD></TR><TR><TD CLASS="quote">
b16a headers will not fit on an ls</TD></TR></TABLE>
Fixed it for you. A B16B header will fit, as it has the same engine block as the GSR and ITR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">
Fixed it for you. A B16B header will fit, as it has the same engine block as the GSR and ITR.</TD></TR></TABLE>
cool, didnt realize that.
Ti3d in
Sep 23, 2005 02:09 PM
BumpinVTEC
Oct 5, 2004 05:30 PM
compwc18
Feb 8, 2004 06:27 PM
