no heat after new water pump
Old Nov 7, 2007 | 06:43 PM
Nutcase4life's Avatar
Default no heat after new water pump
Is there a key to bleeding out all the air that might be in the system? I let my car run for a good 15 minutes with the rad cap off but I'm still not getting hardly any heat.
Old Nov 8, 2007 | 06:02 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: no heat after new water pump (Nutcase4life)
check/replace your t-stat
Old Nov 8, 2007 | 09:43 AM
95 integra's Avatar
Default Re: no heat after new water pump (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">check/replace your t-stat</TD></TR></TABLE>
Is the car heating up or taking longer then normal to do so? Thermostat is the most likely answer, secondly why leave the cap off? No need to do so, if anything you should crack it the first click and leave it on.
Old Nov 8, 2007 | 06:15 PM
It only warms up to a little past 1/4 on the guage the will drop down.I let it idle with the cap off to see about getting the air outta the system.There is no first click on my cap.Once you press down and turn it its off.
Old Nov 9, 2007 | 07:23 PM
poorman's type-r's Avatar
* B A N N E D *
try blasting the heat all the way to 4 w/ the radiator cap open while the car is running... always work for me...
JDM C.A.R
Acura TL, RL & ZDX
Jul 28, 2010 09:26 PM
civicdelsol33
Jun 6, 2008 08:00 PM
EKstacy
Mar 25, 2008 09:54 PM
Outsane
Sep 23, 2004 02:13 PM
MYDA9
Dec 17, 2003 08:30 PM
