tire pressure help
Old Nov 7, 2007 | 05:37 PM
fastjimmy's Avatar
Default tire pressure help
i have a 99 si and am running 205-50-15 kuhmo ecsta ast tires and want to know wht pressure to run in them. i ran 32-34 with my nittos and wonder if i should run about the same in the kuhmos. thanks
Old Nov 7, 2007 | 05:40 PM
doubleshotz's Avatar
Default Re: tire pressure help (fastjimmy)
The MAX pressure should be printed on the sidewalls of your tires.
If the MAX pressure is 40 psi, I'd run anywhere from 34-37 psi, depending on weather.
Even tire pressure on all four corners is best for daily driving.
Old Nov 7, 2007 | 06:52 PM
GreenGSR's Avatar
proper tire pressure is determined by a tire's load index which is the number before the speed rating ex: 95V. where V is the speed rating 95 being the load index. Unless the vehicle weight has changed dramatically from stock, it is best to run the oe recommended air pressure. If the new tires have the same load index as the oe tires, you should run the same pressure. I do believe your kumho's are equivelent in load index to the stock tires. You can always check the placard on the drivers door panel. kumho tires
Old Nov 7, 2007 | 08:03 PM
burke420's Avatar
Default Re: tire pressure help (doubleshotz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleshotz &raquo;</TD></TR><TR><TD CLASS="quote">The MAX pressure should be printed on the sidewalls of your tires.
if you run 37 psi, you better be fat or have almost full capacity in tyour car... but as DTC recommends, run 32 psi
Old Nov 8, 2007 | 10:14 AM
nsxtasy's Avatar
H-T Order of Merit
Stickied at the top of this forum is a topic called
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">Tires FAQ</FONT>
What air pressure should I use in my tires?
As a general rule, regardless of wheel or tire size or type, the best place to start is with the pressure recommended for your CAR, as shown in your owner's manual and on your car either on the door jamb or glove compartment door. Measure the pressure when the car has been sitting for several hours out of the sun, at the outside temperature at which the car will be used. Adjust from there in 2 psi increments as needed, based on tire wear and your preference for handling and/or ride comfort.
Do NOT set the pressure to the maximum pressure indicated on the sidewall of your tire.
kenji51590
Jan 7, 2012 09:13 PM
EF9ZC
Honda Motorcycles
Jul 23, 2006 09:45 AM
tonezilla
Dec 28, 2003 03:49 PM
CereaLand
Sep 4, 2003 05:37 PM
CereaLand
Sep 4, 2003 02:22 PM
