Crome vs Uber vs Hondata vs Neptune vs eCtune vs AEM vs eManage vs AFC
http://www.thewrai6th.com/drop...s.xls
Read, discuss, correct.
This is a feature spreadsheet I came up with to help decide on what tuning application to go with. It is unbiased and created from a user's perspective.
Most of it was from research on websites, downloaded applications and input from other forum members. Any comments or corrections are appreciated.
uberdata has individua fuel trim
Crome has CEL shiftlight.
Crome does not have a good working gear trim
Crome Gold has TPS scaling
41 & 32 are the almost the same, but with two different answers.
Crome gold does have fan control and programable outputs, some work
LOL at the last line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew Peacock »</TD></TR><TR><TD CLASS="quote">FMU pwns all.</TD></TR></TABLE>
LOL
File updated. Any more corrections are appreciated.
LOL
what is, VE Correction, Kill Injectors?
and technically program rom obd0 etc etc doesnt even apply to AEM ems because they have a model for each one.
aem ems also has (the important ones im going to name)...
tps fueling
tps ignition
antilag
customizable switch retard
3 avaliable ignition channels (4 total for COP, ETC)
staged injection (5 avaliable ontop of the 4 you already have)
7 avaliable 0-5v inputs
5 avaliable low side drivers (gnd output)
1 avaliabe high side driver (+12v output)
4 avaliable switch inputs
tps fueling
tps ignition
antilag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly »</TD></TR><TR><TD CLASS="quote">what is, VE Correction, Kill Injectors?
VE correction is map used in open loop I believe, which can be dialed in. Usually I don't touch it.
And kill injectors.... well it kills the injectors. It is nice for checking plugs.
Can you explain these two?
AEM is far beyond the competition when it comes to programable inputs and outputs, but I was just checking for basic functionality (At least two outputs, somewhat programable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th »</TD></TR><TR><TD CLASS="quote">
switch retard, usually used with clutchless shifting, typical setup is on a strain gage, u can set how long it retards/cuts your ignition to unload the drivetrain so u can shift.
staged injection, when you run multiple/additional sets of injectors. couple examples....running smaller injectors(550cc) for good idle/partial throttles, but running large injectors(1000cc+) in high load/boost. post compressor injection with methonal to cool down your air intake temps. on ITB setups, running second set of injectors above the velocity stacks for better atomization....etc
switch retard, usually used with clutchless shifting, typical setup is on a strain gage, u can set how long it retards/cuts your ignition to unload the drivetrain so u can shift.</TD></TR></TABLE>
Crazy, I never heard or thought of that.
staged injection, when you run multiple/additional sets of injectors. couple examples....running smaller injectors(550cc) for good idle/partial throttles, but running large injectors(1000cc+) in high load/boost. post compressor injection with methonal to cool down your air intake temps. on ITB setups, running second set of injectors above the velocity stacks for better atomization....etc</TD></TR></TABLE>
That's what I was thinking, but I wasn't sure where the 5th one was coming from.
Do you know which others can run secondary injectors? I can go digging through the apps again, I know that even eManage supports an additional injection map.
I hadn't really thought of it. Is that a piggyback, or a replacement ecu like the AEM? I'll look into it further and add it to the list.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShawnR »</TD></TR><TR><TD CLASS="quote">no motec?</TD></TR></TABLE>
few other things.
Hondata S200 has realtime update.
Hondata S300 has target a/f tables
You should add internal datalogging. S300, AEM have it.
Modified by Turbogixxer at 1:48 PM 11/8/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">few other things.
Modified by Turbogixxer at 1:48 PM 11/8/2007</TD></TR></TABLE>
Fixed, fixed and added.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 »</TD></TR><TR><TD CLASS="quote">Not all the information in that xls is accurate.
one of the most obvious mistakes:
crome pro does have datalogging capabilitys!</TD></TR></TABLE>
I know it is not 100% correct, I need feedback from the people who are tuning with these apps. With some input, it could be 100% accurate.
They market datalogging as a "Dealer" feature, but I see that it is part of Pro. Fixed.
Holy crap, Motec should get it's own section. I have not seen Telemetry built in to any other product. Very advanced. I will work on getting Motec (and it's many features) added to the list.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th »</TD></TR><TR><TD CLASS="quote">I hadn't really thought of it. Is that a piggyback, or a replacement ecu like the AEM? I'll look into it further and add it to the list.
lol
http://www.motec.com - Not really fair to compare to the others. Might as well throw in all the standalones then...
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .dave »</TD></TR><TR><TD CLASS="quote">
lol
http://www.motec.com - Not really fair to compare to the others. Might as well throw in all the standalones then...</TD></TR></TABLE>
Tuning options are tuning options. List them up and I will research them as best as I can.
I added some info on MOTEC already.
lol
Accel DFI
AEM EMS
Anderson Ford PMS
APEXi
Autocar Electric
Autotronic
BikiRom
CROME
DiabloSport
DTA Competition EMS
Edelbrock
EFI332
EFI Systems, Inc.
EFI Technology
EFILive
Electromotive Engine Controls
Emrald M3D
EvilScribe
F.A.S.T
GEMS, Ltd.
Greddy
HALTECH
Hestec
HKS
Holley
Hondata
HP Tuners
LINK Electrosystems
LifeRacing
LT1 Edit
MBE Systems
Megasquirt
Microtech
MoTec
MR Controls
MSD Ignition
NepTune
Omex Technology
Ontronic EFI
Pantera Specialists
Pectel Control Systems
Perfect Power
Performance Electronics
Racetech Development
Redline Weber
SDS-EFI
Tunercat
TunerPro
TwEECer
VEMS Group
WEBCON UK LTd.
Wolf EMS
And thats a incomplete list... I know some of that stuff does not apply to Honda/Acura but the point remains there are a crapload of standalone's out there...
You should narrow it down more otherwise the spreadsheet will get out of control...
I think you should just narrow the comparison to Piggyback, ECU chipping/reflash. Maybe add additional worksheets for Standalones as they are a completely different animal and have specialized hardware...
Cool comparison though...
AEM EMS
Anderson Ford PMS
APEXi
Autocar Electric
Autotronic
BikiRom
CROME
DiabloSport
DTA Competition EMS
Edelbrock
EFI332
EFI Systems, Inc.
EFI Technology
EFILive
Emrald M3D
EvilScribe
F.A.S.T
GEMS, Ltd.
Greddy
HALTECH
Hestec
HKS
Holley
Hondata
HP Tuners
LINK Electrosystems
LifeRacing
LT1 Edit
MBE Systems
Megasquirt
Microtech
MoTec
MR Controls
MSD Ignition
NepTune
Omex Technology
Ontronic EFI
Pantera Specialists
Perfect Power
Redline Weber
SDS-EFI
Tunercat
TunerPro
TwEECer
VEMS Group
WEBCON UK LTd.
Wolf EMS
