F/S- Literally BRAND NEW FULLY BUILT 2001 GS-R BLOCK WITH RECIPETS AND PAPERS
OK here is my person 2001 ACURA INTEGRA GS-R FULLY BUILT BLOCK SPEND OVER 3,000 ALONE ON THIS BLOCK AND LOOKING FOR ABOUT HALF.
There’s 0 miles, yes ZERO miles never driven mounted never oil or antifreeze installed only thing is torco engine lube that’s it
This is out of my 2001 gs-r that I still have proper paper work and copy of vins papers included also all receipts of everything nuts, bolt and items included.
Have plenty of pics and pics of recipes just ask and ill send you more
http://i83.photobucket.com/alb...2.jpg
Also please serious buyer no windows shoppers NO TRADES CASH or pay pal only (must add fees)
Shipping is anywhere from $150.00-200.00 for ups
Block included 0 (ZERO) MILES
http://i83.photobucket.com/alb...n.jpg
http://i83.photobucket.com/alb...3.jpg
Here’s the machine work
Clean block
Check for cracks
Bore and hone to 81.5mm
Balance entire engine assembly
Clean deck and check for straight ness
Check crankshaft
Assemble short block
Micro polish crankshaft
Replaced all main bolts
Replace all seals
Replace bearings-
Install pistons on rods
Equals- $1400.00
http://i83.photobucket.com/alb...k.jpg http://i83.photobucket.com/alb...k.jpg
Parts
Eagle rods with Arp rods bolts=300.00
Superset Gas Nitride 5.9cc Pistons=450.00
Password jdm-magnetic drain plugs 28.00
B&R Block plug 30.00
Torco Engine Lube-18.00
Calico ACL Coated bearing (Main, Rods, Thrust washers) =145.00
OEM ACURA bottom end gasket kit-90.00 including every gasket for bottom end entirety
OEM ACURA Water pump-95.00
OEM ACURA ITR Oil pump-96.00
OEM ACURA Tensioner and spring=60.00
OEM ACURA Oil Seal=12.00
Equals=$1,324.00
http://i83.photobucket.com/alb...4.jpg
http://i83.photobucket.com/alb...5.jpg
http://i83.photobucket.com/alb...6.jpg
http://i83.photobucket.com/alb...7.jpg
BLOCK has literally everything new parts included
ALL READY ASSEMBLE READY FOR INSTALL
Oil pan
OEM oil pan gasket
Oil pick up
OEM oil pick up gasket
Block with proper paperwork and all receipts original too
Pistons
Rods
Crankshaft
Block plug
Stock crank pulley if I can find it lol
Water neck and alternator and bracket not included
http://i83.photobucket.com/alb...1.jpg
Needed to install is head, timing belt, alternator, water neck, head gasket and motor oil thanks it
Totals 2,724.00 ACUALLY HAVE ALL RECPIECTS TO PROVE THESE EXACT PRICE
Looking for 1850 Shipped around the u.s OR BEST OFFER NO TRADES AT ALL NOTHING BUT CASH BUMP IF VIEW
HAVE ALL EXACT SPECS ON BLOCK IF NEEDED LET ME KNOW THANKS
Any serious offers pm or email me at
Hd17f@yahoo.com
Clean block
Check for cracks
Check crankshaft
Replace all seals
Replace bearings-
Equals- $1400.00
Parts
Equals=$1,324.00
Oil pan
OEM oil pan gasket
Oil pick up
Pistons
Rods
Crankshaft
Block plug
Hd17f@yahoo.com
That's a good deal, assuming once installed, it has good compression and leakdown numbers.
i have teh clearances here next to me all within honda recommend clerances all great spins freey and greaty awsome block which didnt have to sell but went the other way with my build so need to pay my debt thanks for the but
2001B18C1GS-R
Northeast (Sales)
12
Nov 12, 2007 04:16 PM
2001B18C1GS-R
Nov 12, 2007 04:15 PM
