check engine light turns on randomly and then when i restart the car it goes away?
Old Nov 7, 2007 | 11:59 AM
ramz7887's Avatar
Default check engine light turns on randomly and then when i restart the car it goes away?
The check engine light comes on randomly when I'm idling at a stop light. Then when i get home and shut the car off and turn it back on the light goes away. There is no change in driving performance.
Old Nov 7, 2007 | 01:35 PM
havok hybrid's Avatar
Default Re: check engine light turns on randomly and then when i restart the car it goes away? (ramz7887)
first guess . Your O2 sensor is f*ked up . Or you have a chipped ecu with o2 sensor disabled. ??
next time the check like is on . pull the code off the ecu. . (Jump service connector at ecu)
Modified by havok hybrid at 11:37 PM 11/7/2007
Old Nov 7, 2007 | 05:25 PM
Chiovnidca's Avatar
What trouble code does it have stored? Year and model?
Old Nov 8, 2007 | 07:56 AM
Relic1's Avatar
even though the light turns off when you restart the car, the ECU still has the error code in memory.
Pull the codes, go from there.
(go to parts store and have them pull them, or do it yourself like the sticky shows.)
Old Nov 13, 2007 | 04:34 AM
ramz7887's Avatar
Default Re: (Relic1)
Its a stock p72 . I went to auto zone and they said that the computer didn't store a code. The car is a 98 and the ecu is form a 93.
Old Nov 13, 2007 | 04:35 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (ramz7887)
leave the car running and check the code, it could possible be comming on for random misfire's.. check your plugs
so your running a conversion harness from your engine harness to your ecu correct? obd1
Old Nov 13, 2007 | 03:07 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 &raquo;</TD></TR><TR><TD CLASS="quote">Its a stock p72 . I went to auto zone and they said that the computer didn't store a code. The car is a 98 and the ecu is form a 93. </TD></TR></TABLE>
You're gonna need to check the codes manually. The obd2 scanners autozone uses wont read your ecu. Jump the service check line to get the codes to flash.
Darth CRX
Apr 29, 2014 07:33 AM
crxaddikt
Dec 1, 2003 09:23 AM
BigMig
May 10, 2003 06:01 PM
type Gendy
Apr 21, 2003 04:48 PM
