My Acura has a ticking sound by my Cam Sprokets!
Old Nov 7, 2007 | 11:00 AM
Augy1's Avatar
Default My Acura has a ticking sound by my Cam Sprokets!
My car has this ticking sound by my Cam Sprokets and tends to go away when the car get's warm. I had this for a couple of days and now my car when just idleling tends to want to turn off, it like boggles and my check engine light is now on. Any recommendations or help is appreciated.
Old Nov 7, 2007 | 11:06 AM
SoTexDC2's Avatar
Start by retrieving the CEL code.
A Valve Lash adjustment, and checking your ignition timing will also help.
Old Nov 7, 2007 | 01:37 PM
mc-integra111's Avatar
Default Re: (SoTexDC2)
A couple of other ideas are to check the play of the cam sprocket on the cam (Maybe the key is work and causing excessive play) and the cam timing marks (maybe it skipped a tooth). Skipping a tooth usually would make the engine not run at all, but it depends.
Old Nov 8, 2007 | 04:15 AM
SoTexDC2's Avatar
Default Re: (mc-integra111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc-integra111 &raquo;</TD></TR><TR><TD CLASS="quote">A couple of other ideas are to check the play of the cam sprocket on the cam (Maybe the key is work and causing excessive play) and the cam timing marks (maybe it skipped a tooth). Skipping a tooth usually would make the engine not run at all, but it depends.</TD></TR></TABLE>
In my experience, the car will run if the timing belt is incorrectly set by a few degrees. It will lack power and run sluggish though.
v!taminb16
Apr 5, 2008 06:44 AM
johnclaunch
Apr 3, 2008 09:27 AM
CARMA_626
10
Jul 26, 2006 10:16 PM
cadougherty_67
Mar 6, 2005 06:11 AM
dsadas89das78934
22
Jan 24, 2004 04:37 PM
