tips to install WW body kit 88 crx
Old Nov 7, 2007 | 09:32 AM
BOSS-REX's Avatar
Default tips to install WW body kit 88 crx
I need some tips on how to instal the rear WW kit bumper on crx 88. Its the urithane one. all the rest of the kit is on and looks good.
Modified by BOSS-REX at 10:45 AM 11/7/2007
Old Nov 7, 2007 | 09:38 AM
jfish360's Avatar
Default Re: tips to install WW body kit 88 crx (BOSS-REX)
screw it on.
Old Nov 7, 2007 | 09:47 AM
BOSS-REX's Avatar
Default Re: tips to install WW body kit 88 crx (jfish360)
funny
Old Nov 7, 2007 | 10:58 AM
loudandlow's Avatar
ok, here is what you do....
take off the kit and burn it!
Old Nov 7, 2007 | 12:14 PM
24TEN's Avatar
PHANTOM MENACE
Seriously, you screw it on. You should have some way to mount it to the "T" bar/radiator support and/or bumper support and then mount it to the sliding clips towards the inside of the fenders.
Old Nov 7, 2007 | 12:25 PM
BOSS-REX's Avatar
Default Re: tips to install WW body kit 88 crx (24TEN)
yes I had it hooked up that way, but the fit up did not fit good, I think do to the bumper t-bar the rear bumper, the factory side clips did not fit nicely eather, and one more thing the bumper is about 1/2 inch wider than the back of the car
Old Nov 7, 2007 | 12:29 PM
RockinthEFhatch's Avatar
That's just the way it is... you can't at all expect a kit like that to fit perfect. Just keep tweaking it, you'll get it. It took me about 3 hours to make my JDM front to fit perfectly I'm sure it could take twice as long in your situation but it'll look fine. Work on adjusting the front support beam as well as the rear since that's where the bumpers are connected.
Old Nov 7, 2007 | 12:36 PM
24TEN's Avatar
PHANTOM MENACE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOSS-REX &raquo;</TD></TR><TR><TD CLASS="quote">...the bumper is about 1/2 inch wider than the back of the car</TD></TR></TABLE>
That's actually not too bad, I've seen much worse. Quick question, are you sure that the rear is for a CRX and not a hatch? Any pics too? I'd like to see...
PS disregard the radiator support part, I thought you meant front. The rest is still applicable though to the rear.
Old Nov 7, 2007 | 12:52 PM
omg_miiiike's Avatar
I'll buy it from you just so I can run it over a few times .
Old Nov 7, 2007 | 01:16 PM
BOSS-REX's Avatar
Default Re: tips to install WW body kit 88 crx (omg_miiiike)
the front is on the sides are on and looks good to pant just wanted some extra info on the back bumper. the car sticks to the ground much beter than befor and gets two miles per gal better
Old Nov 7, 2007 | 01:27 PM
BOSS-REX's Avatar
I got it strait from the factory in city of industry real certain its for the crx but ill call WW and make sure again.
Old Dec 1, 2007 | 08:26 AM
nabin's Avatar
dude......... all wings west **** doesnt fit right.....
if you scrwe the sides on where they are supposed to be, and then screw in some on the middle part, let it sit in the sun, or if you have an industrial heater, heat that bitch up. Urethane is plyable and will bend. if you leave it on your car a little bit and let it get warm, it will fit better. believe me, i had the exact same problem wiht my rex, and I PAINTED IT MYSELF!!
Old Dec 1, 2007 | 09:13 AM
Markland Photo's Avatar
posting pics would probably help as well
h22a_junkie
May 7, 2006 04:21 PM
Nocturnal
Jan 14, 2003 09:42 PM
Neospite
May 23, 2002 06:33 PM
phatcivic99
Mar 10, 2002 06:25 AM
