95 Accord EX Coupe, A/C not working....
I have a 95 Accord EX coupe and the a/c unit isn't working. Only blowing out hot air when its turned on. Do you guys know what I can check to see what can be the problem?
I did do a search but didn't really come up with much help. Thanks!
recharge the system using r134a that has a florescent dye added.. clean the engine bay and drive arould for a while with the defroster on. search for leak, repair it. evacuate system and hold on vaccum for at least 4 hours and then recharge if it holds vaccum. use proper amt of pag oil and r134a
matty0234
May 9, 2011 07:48 PM
