Door Freezing?
Old Nov 7, 2007 | 04:10 AM
123Four's Avatar
Default Door Freezing?
Share your tips on keep your door from freezing over winter? For example key hole and the weather strip around the doors. I’m thinking wd40 will do the trick for the key hole but what about the rubber strip that’s around the door?
Old Nov 7, 2007 | 04:24 AM
King V's Avatar
Default Re: Door Freezing? (123Four)
A can of silicone would do the trick.
Old Nov 7, 2007 | 03:26 PM
123Four's Avatar
Anyone else got any other advice?
Old Nov 7, 2007 | 03:27 PM
nix94delsol's Avatar
leave your doors open
Old Nov 7, 2007 | 03:32 PM
93egSLEEPER's Avatar
Default Re: Door Freezing? (nix94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">leave your doors open</TD></TR></TABLE>
LOL.
wipe out your door jambs to get all the moisture out when your done driving for the day. I do that and it seems to work and keeps the door jambs clean.
Old Nov 7, 2007 | 04:56 PM
Padawan's Avatar
Darth ModerVader
WD-40 will work on the lock and on the rubber seals.
Old Nov 7, 2007 | 05:25 PM
slowcivic2k's Avatar
Vaseline is what I use, good up to (or should I say down to) -10 or so.
Oil the key with a light oil, preferably silicone lube so it doesn't leak down onto the window, and stick it in there.
m.glisson003
Aug 7, 2011 12:36 PM
globy123
15
Oct 26, 2010 01:13 PM
Deviation
17
May 24, 2006 01:47 PM
kniob
Mar 27, 2004 03:06 PM
CB_ejcoupe
Jan 26, 2004 02:35 PM
