Help with Toda ITB's
Hi guy's, about to acquire the toda ITB's and have a couple of Q's....
My question related to whether the head needs to be welded to achieve maximum gains or whether the itb's can be bolted on without any modification. I'm a little unsure about the process of welding of the head so if anyone has detailed info/suggestions, I would love to hear about it (of-course i will have it done by an engineer so no DIY's here)...
Thanks from Australia
Jansen
Jansen
If you are referring to the combustion chambers welded and then re-shaped then NO...
however, you will need higher compression,cams of some sort, and an exhaust to flow all of that intake air.....
also, the key ingredient will be a stand alone ems, and a competent tuner.....
Quick search "ITB" using only archived content from the Type R forum:
https://honda-tech.com/zerosearch
I'm still looking for a particular thread discussing ITBs.
https://honda-tech.com/zerothread?id=2028525
*Still searching.
*Still searching.
sorry guys.. i'll list my engine...
Toda valve train, toda pistons, mugen intake , toda header, RM01A exhaust, power fc, e.t.c.
I guess she's built... I really do not have many mods left for me so I guess the ITB's are next...
And yes, welding refers to the inlets on the combustion chamber
What cams are you running with them?
ITB's you do NOT want to weld...get a outlaw engineering IM gasket and bolt that sucker on. Ive been running two of a kind Jenvey ITB's for a year now and it idles and runs like stock except the additional 60whp...
Dee_SydekicK
Jan 19, 2006 07:10 PM
to "cmdr430"
