Clutch adjustment
on the trans there is a bracket that holds the clutch cable. it is a bronze colored bracket that is bolted on. the clutch cable has threads and an adjuster wheel that sit in that bracket. by threading the adjuster wheel clockwise from the top, you will be tightening the tension and pulling the throwout arm up.
