Acura transmission interchangeability question
Old Nov 6, 2007 | 08:30 PM
trustnoone5656's Avatar
Default Acura transmission interchangeability question
I have an Acura Integra transmission. Located on the transmission there is a number : CG-6028824. Here are some links to information I found on CG series transmissions:
http://www.midwesttrans.com/tr...l.htm http://www.eliterides.com/tech....html
My question is, which honda vehicles would this transmission be able to work in with the stock engines?
Also, which other engines would this transmission be compatible with?
Thanks
Old Nov 6, 2007 | 09:08 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Acura transmission interchangeability question (trustnoone5656)
from the looks of those links you found, they appear to be the first or early second gen integra transmissions, so most likely something like the brown top zc motors or something older like that. i would say your links are more helpful than anything. how did you come across it?
Old Nov 7, 2007 | 07:22 AM
Default Re: Acura transmission interchangeability question (sanimalp)
A friend of mine gave it to me. Said he pulled it out of an accord (don't know what year- may not have even been an accord). I really want to sell it and have no idea how to advertise it. Couple years ago I tried to install it in my 91 HF which was stock at the time, and the splines didn't match.
Old Nov 7, 2007 | 08:01 AM
jlicrx's Avatar
CG is 86-89 Integra transmission - doesn't fit anything else - can be used when swapping a D16A1 or JDM "browntop" DOHC ZC into 1st gen CRX or 3rd gen Civic
krazeericeboi54
Oct 30, 2011 11:16 PM
JDM_SAN
May 6, 2008 03:44 AM
queensny
Acura TL, RL & ZDX
Jun 13, 2005 09:49 PM
Luke84
Acura TSX
Aug 30, 2004 02:03 PM
