please help
Old Nov 6, 2007 | 06:50 PM
northemt88's Avatar
Default please help
i just did a rear disc conv. on my 1991 civic hatch std,i used all of the 1992 DA components for some reasson the back right side wobles alittle when i change lanes in the freeway.could it be that i need to adjust my toe or camber?..... the e brake cable was perfect wasent to long.please help
Old Nov 6, 2007 | 07:13 PM
mr.speaker's Avatar
Default Re: please help (northemt88)
you're supposed to re-use the stock upper and lower control arms,,only use the trailing arms from the integra..
I dont know if that's your problem,but all the disc brake swaps I've done,I've never used the control arms from the integra.
Old Nov 6, 2007 | 07:40 PM
freddysEF's Avatar
you can use the lower control arms of the DA because i've use it on my EF but NOT THE UPPER CONTROL arms, their to short, if thats not you problem then its most likely rear the bushings. hope that helps
Old Nov 6, 2007 | 11:20 PM
Fezzie's Avatar
Default Re: please help (freddysEF)
something might be loose, and you should have got it aligned when u first did it.
JDM JEFFREY
Nov 30, 2010 06:18 AM
89civicdx
Jul 23, 2008 06:37 PM
matt1982
Mar 17, 2007 09:45 AM
russianswty
39
Jan 25, 2007 12:02 PM
