Interesting info black bumper recently
Old Nov 6, 2007 | 06:25 PM
94vtirozguy's Avatar
Default Interesting info black bumper recently
Here is a list of things i have checked so far:
spark plugs - look fine (nice brown color)
leads all test ok
no ECU codes been thrown
thermostat is performing correctly
TPS reading correctly
MAP sensor looks to be working fine
yet the rear bumper is covered in black still. This has happened only recently.
i will check the PVC valve tonight... can anyone else got any clues ?
Old Nov 6, 2007 | 06:30 PM
h23vtecpowered's Avatar
Default Re: Interesting info black bumper recently (94vtirozguy)
umm is it like a oily black or like exhaust chalky black
Old Nov 6, 2007 | 06:34 PM
Old Nov 6, 2007 | 06:56 PM
Dave0338's Avatar
Default Re: (94vtirozguy)
Oxygen Sensor? my black bumper went away after that..
Old Nov 6, 2007 | 07:19 PM
Default Re: (Dave0338)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave0338 &raquo;</TD></TR><TR><TD CLASS="quote">Oxygen Sensor? my black bumper went away after that..</TD></TR></TABLE> x2
Old Nov 6, 2007 | 07:33 PM
i would have thought that if the O2 sensor went bad, the ecu would throw a code ?
Old Nov 6, 2007 | 07:50 PM
thats true. but it could be on the verge of going out. **** who knows. it fixed my prob
Old Nov 6, 2007 | 07:59 PM
ok something to check anyway... it should output between 0v and 1v.
Old Nov 6, 2007 | 08:32 PM
yea they can be pricey though. i had a extra one laying around
Old Nov 10, 2007 | 06:52 PM
ok accordingy to my honda the O2 sensor is sitting at 3.28V.. which is not good... next point is... is the o2 sensor really needed seeing i have hondata setup.
Also cleaned out the PCV valve at the same time
Old Nov 11, 2007 | 12:44 AM
v4lu3s's Avatar
RTFM
if you are not going to run your o2 sensor you need to have a much better tune so that it is lean enough during daily driving.
Old Nov 29, 2007 | 03:26 PM
update... just to make sure the O2 sensor was not the issue, i installed a new one today... however the new one was saying 3.28v as well. Which to me means the tune is running way too rich....
oh well time for a re-tune!
Old Nov 29, 2007 | 03:43 PM
integra15's Avatar
What type of fuel have you been using?
Old Nov 29, 2007 | 05:01 PM
car was tuned for 98 octane, and it is running 98 octane so nothing changed in that department.
Old Nov 29, 2007 | 05:07 PM
SLIPSTICK TIPPIN's Avatar
this could be due to climate change or from a rich tune. my car runs rich and its fine if i beat on her but if you baby it like i do it carbons up too a little and this happens to my car too
Old Nov 29, 2007 | 08:17 PM
prelude_h22vtec's Avatar
02 sensors do not read 3v.... unless it is a wideband. those read 0-5v where as a narrowband reads 0-1v. but if its reading 3.28v and its wideband, that is not rich. and also is that with the car running? or just key on engine off? with the engine on, the 02 voltage should fluctuate between rich and lean.
Old Nov 29, 2007 | 09:09 PM
its stock the original one, and the replacement i tested is new, both read the same.
Neither are wideband.
Hondata shows 3.28V for the o2 sensor reading.
Old Dec 1, 2007 | 04:31 PM
well if they arent reading you've got some kind of problem, maybe a open circuit somewhere or a short.
skyviewLA01
Paint and Body
Sep 20, 2016 11:18 AM
import_girl
Honda Civic (2006 - 2015)
Dec 20, 2006 04:42 AM
Neiser
May 22, 2005 08:31 PM
A D NOH
Apr 17, 2003 10:08 AM
