A couple of conversion questions
First, will the USDM bumper support / radiator support work when doing a SiR frontend conversion??
Second, can i use the rear disc from a '94 Integra GSR to do a rear disc conversion?? I've searched, and some people say yes, others no, and some say it works but there will be camber issues. I read the FAQ and could not find any info on a conversion from a DC Integra...
http://forums.hondatuningmagaz....html
Yes, I know rear disc from a Si is the easiest, but its hard to find. I have access to a GSR and I was wondering if i should get it or pay for the disc from a DA??
no, the SiR bumper support is small as ****, thats why the jdm bumper is so much lighter
and .. since idk the correct answer to the conversion part, im not going to answer...but I THINK you can, i know people on honda tech have done an integra disc swap...which im sure is the same with each integra, maybe except the r..but i think it does make the rear wheels actually stick out a little.
but idk, sorry.
but idk, sorry.
CRX OR HATCH?? well if CRX then yes the siR conversion will work with the usdm bumper support ive seen it done but with a little cutting.....i would suggest getting the hf crx bumper support looks similar to the jdm siR one and is very light! the DC teggy rear discs brakes i heard theyll fit dont know bout the camber issue! good luck.....
