bunch of parts.... D16Y8, D16Y7, B-series, ZC...and misc....
99-00 Civic EX/DX/LX/CX/D16Y7/D16Y8 distributor w/ignition wire set - $60
D16Y7 intake manifold/throttle body/injectors/whatever you see willing to part - make offers
99-00 Civic LX/DX/CX engine wiring harness (PN: 32110-P2F-A50) - $80
88-89 Integra/ZC OBD0 distributor - $50
D16Y8 intake manifold/TB/injectors/clips/MAP/fuel rail... might spilt - $70
Python/Venom 1000cc injectors...flow tested/cleaned with chart/receipt/etc... but one doesnt pulse when in the car? - $80
B18C SiR-G JDM pistons x 2 - $20
88-01 Civic/del Sol/Integra/CRX OEM rear lower control arms w/ok bushings - $40
B-series fuel rail (cast, flat black in color) - $15
OBD1 injectors (set, with all the **** ground off lol so they fit OBD0 or OBD1 clips) - $10
EG calipers - $30
B-series pressure plate - $20
cable D starter - $20
EH2 driver manual mirror (OEM) - $20
EH2 passenger manual mirror (aftermarket/TYC) - $20
EG driver corner - $10
SiR-G (B18C) exhaust manifold - $40
Samco blue hose B-lower - $30
passenger tranny mount filled with urethane - $20
B-series 94-01 throwout bearing fork - $10
B-series intake valves - $5each
B18C SiRG block *BARE* w/caps cracked sleeve - $150
complete rear drum swap - $20
86-87 PG7 - $25
P72 intake manifold, bare... - $5 pickup
thats all i found for now... have or can take pics for the rest of the **** if you really want them, just lmk...
EG calipers - $30
86-87 PG7 - $25
