Suspension & Brakes Theory, alignment, spring rates....
just got my ksports coilovers
Old Nov 6, 2007 | 04:28 PM
hatchreborn's Avatar
Default just got my ksports coilovers
hey fellas i got a quick question maybe ya can help me..
i just got in my ksports coilovers for my 92 eg hatchback,
can someone tell me what else will i need for my suspension
before i put them in?
appriciate it thankss
Old Nov 6, 2007 | 05:12 PM
Default Re: just got my ksports coilovers (hatchreborn)
bumpp help me outt wit some adviceee
Old Nov 7, 2007 | 05:30 AM
og asr's Avatar
you will be happy....try to set up 4 clicks in front...and 3 in back......not too hard...and comfortable for daily driving.
Old Nov 7, 2007 | 08:44 AM
Agent_EM1's Avatar
im about to get some too
Old Nov 7, 2007 | 07:53 PM
EK_B's Avatar
You need antiseize when you install the bolts back on.
Old Nov 7, 2007 | 09:40 PM
.:Made in OC:.'s Avatar
Default Re: (EK_B)
camber kit, alignment!
Old Nov 8, 2007 | 03:18 AM
bmoua's Avatar
Default Re: (.:Made in OC:.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Made in OC:. &raquo;</TD></TR><TR><TD CLASS="quote">camber kit, alignment!</TD></TR></TABLE>
Old Nov 8, 2007 | 07:21 PM
ap716's Avatar
bushings, ball joints?
Old Nov 8, 2007 | 10:57 PM
blinx9900's Avatar
Default Re: (ap716)
a good warrenty and garage space for when you have to take them out in 9months...
Old Nov 9, 2007 | 06:40 AM
KaBlookie's Avatar
Default Re: (blinx9900)
^^ meh, mine are like 2 or 3 revisions old and lasted 14 months before the rears went out, and the fronts are still cherry after almost 2 years and over 20k miles...the newer ones have different damper oil, better seals, apparently better construction, and clicking damper adjustments. I can't vouch for their longevity, exactly, but they should last longer than the ones that have been giving some people problems.
to the OP...aside from what comes in the box, you don't NEED anything else at all to install them on your car. A camber kit will only help with a little bit of tire wear, but be SURE to get an alignment as soon as you set the ride height to where you want it.
Old Nov 11, 2007 | 05:22 PM
Default Re: (KaBlookie)
bumpp good looks
for the price i got them .. not really tryna to get more than a yr or so outta them
Old Nov 11, 2007 | 09:44 PM
civic2sick's Avatar
Default Re: (hatchreborn)
You should be able to install them by them selves. I would recommend a camber kit, but its not needed. I would also get an alignment shortly after the install if you change the height.
Old Nov 12, 2007 | 10:21 AM
KaBlookie's Avatar
Default Re: (civic2sick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2sick &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to install them by them selves. I would recommend a camber kit, but its not needed. I would also get an alignment shortly after the install if you change the height.</TD></TR></TABLE>
If you're not going to be slamming your car (IE. tucking tire), I would recommend NOT getting a camber kit. The camber kit upper arms stick out more and likely will hit your shock towers when they compress (especially with EG and EF civics), eventually poking holes, making them weaker, etc. etc.
Just put them on, set the height, and get an alignment. If you're not slamming it, you're not going to have so much camber that it'll eat through your tires. Toe eats tires much faster than camber does.
PrittyPearllude
Suspension & Brakes
Apr 11, 2006 06:50 PM
god.loves.ugly
Mar 6, 2006 12:05 PM
billyzakkus
Nov 28, 2003 12:07 PM
FlaN.
Sep 21, 2003 06:53 PM
RedRacer
Oct 29, 2001 04:54 PM
