84.25mm piston rings in 84.50mm pistons
Old Nov 6, 2007 | 04:16 PM
ef9_b16a1's Avatar
Default 84.25mm piston rings in 84.50mm pistons
hi
i have je 84.5 b series pistons.
i cant find je rings anywhere in greece, they selle them as a set wiht pistons only
if i use the 84.25mm oversize b20 crv oem honda rings i can find here, will i be ok with end gaps?
is it a big diference?
thanx for any info.
Old Nov 6, 2007 | 06:34 PM
NJIN BUILDR's Avatar
Default Re: 84.25mm piston rings in 84.50mm pistons (ef9_b16a1)
No,the gap will be to big with the 84.25 mm rings.
b20vtech
May 10, 2007 06:23 PM
ssr_h22
Sep 6, 2004 09:21 AM
swlabhot
May 13, 2004 01:38 PM
nicklk
Jan 27, 2004 12:58 PM
