how do you change the chip in a ecu without messin it up
Old Nov 6, 2007 | 02:11 PM
BUDtoker's Avatar
Default how do you change the chip in a ecu without messin it up
Old Nov 6, 2007 | 02:32 PM
pythoner's Avatar
if your ECU has been chipped, it has a ZIF (zero insertion force) socket and you just lift the lever and change the chip. If its not chipped, get it chipped and then change the chip
Old Nov 6, 2007 | 02:33 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: how do you change the chip in a ecu without messin it up (BUDtoker)
ummm, buy a chipped tested ECU
then have someone that tunes hondas and works for a company with a dyno dyno tune it.
thats about the only way.
Old Nov 6, 2007 | 02:38 PM
BUDtoker's Avatar
Default Re: how do you change the chip in a ecu without messin it up (EGmikeH22)
ok so how do i protect the chip from static electricity?i have a p06 that has been modified to a p28 it is socketed and chipped i just need to change the chip out!
Old Nov 6, 2007 | 04:15 PM
Boost'd EJ1's Avatar
javascript:popupWindow('http://www.xenocron.com/catalog/aries-zif-socket-pi-196.html') lift the lever and chip comes out
Old Nov 6, 2007 | 04:22 PM
ddd4114's Avatar
Default Re: how do you change the chip in a ecu without messin it up (Boost'd EJ1)
Mine doesn't have a ZIF socket. His might not too. If that's the case, you just pull up on the chip, and it'll come right out.
As long as you're grounded, you're not going to damage anything from a static shock.
Oh yeah, and don't put the new chip in backwards. I'm not sure if it will actually do any damage when you try to start the car, but it's never a good idea.
Old Nov 6, 2007 | 06:24 PM
RiceKillinSI's Avatar
Default Re: how do you change the chip in a ecu without messin it up (ddd4114)
http://www.pgmfi.org/twiki/bin...bHome
Here is everything you need.
BUDtoker's Avatar
how do i ground myself? what is the best way?
Vtec140
Oct 3, 2017 02:15 AM
Brandeezy1
Engine Management and Tuning
Jul 25, 2012 07:18 AM
hondaeg8
Jan 12, 2005 08:47 PM
Slow Egg
Mar 20, 2003 09:07 PM
