04 Civic Si Seats in a 92 EG
has anybody been able to install/modify 04 civic si seats to fit into a 92 eg si? if this is in the wrong forum i apologize. any suggestions or help is much appreciated. thanks
jay
jay
Either you make custom rails or you modify the EP3 mounting points (I did the latter).
(People say that the welds aren't safe...they've been like that for almost a year with no problems. Plus, welds are stronger than the metal that they join
EDIT:
The rear mounting points line up ok (need a little pushing to line them up properly), the front are completely different than the EG's. I cut the EP3 front brackets off, bolted them down and flattened them out with a hammer. Then my buddy tack welded them, we pulled them out and welded them fully
)EDIT:
do you have any pictures of the front brackets? that rear bracket thats welded looks good to me. as per the other rear bracket it just bolts down? thanks again bro.....
jay
jay
stevel
Sep 15, 2006 10:20 AM
