what kind of rotors
Old Nov 6, 2007 | 01:36 PM
hatch96y7's Avatar
Default what kind of rotors
i am looking to upgrade my rotors because i am tired of the rusty look.
i was wondering what type of rotors can i purchase.
i was looking at the brembo slotted rotors.
but i am not sure exactly what type.
i know that drilled rotors are useless so that isnt really an option.
Old Nov 6, 2007 | 02:36 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: what kind of rotors (hatch96y7)
you've "heard" that drilled rotors are useless.
anyone with little enough information on rotors that they'll go to HT and just ask like that should first assume they know less than that about what they're asking about.
if you're tired of a "look" get a different "look"
if you're tired of rust, get some brembo blanks or drilled or slotted, or drilled/slotted.
whatever makes your magic stone glisten.
Old Nov 6, 2007 | 02:55 PM
Padawan's Avatar
Darth ModerVader
Just pick up a set of AutoZone/Duralast or Brembo blanks. If you don't want the hats to rust, paint them with brake paint.
Old Nov 7, 2007 | 06:40 AM
hatch96y7's Avatar
Default Re: what kind of rotors (Padawan)
okay but ive heard on ht that even top manufacturers admit drilled rotors are just show. because the pad grabs less surface area
Old Nov 7, 2007 | 06:48 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">okay but ive heard on ht that even top manufacturers admit drilled rotors are just show. because the pad grabs less surface area</TD></TR></TABLE>
the purpose of drill rotors is to disperse heat better...better ventilation
slot rotors will have better braking. because of friction. (physics)
Old Nov 7, 2007 | 06:59 AM
90efhatch's Avatar
I have had Brembo Drilled rotors on my EF for years now and autocross the car and hae not had any problems with them. Thats my experience though. I would definitely stick with a good manufacturer though like Brembo or equivalent.
Old Nov 7, 2007 | 07:08 AM
Luserkid's Avatar
Default Re: (90efhatch)
I guess Benz and BM use them just for show too huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">
slot rotors will have better braking. because of friction. (physics)</TD></TR></TABLE>
Only downside to drilled rotors on daily driving is with basic pads they wear out faster. I believe if you get upgraded pads with stronger material they last alot better (kavler i think).
Old Nov 7, 2007 | 08:29 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I guess Benz and BM use them just for show too huh? </TD></TR></TABLE>
As a matter of fact, a good portion of that is indeed for aesthetics. High-end auto manufacturers are not immune to the customer's demand for a "sporty" appearance. Also keep in mind that some of these high-end rotors are actually cast with the holes, not drilled. In most situations where brakes are used <u>hard</u> in a track setting, drivers tend to find that the drilled rotors are more prone to developing cracks, and do not provide a discernible benefit. In fact, the holes actually reduce the overall mass of the rotor, thus also reducing its ability to absorb and dissipate heat. A well-designed internal vane structure is far more important than holes, but obviously doesn't offer the "bling" that many people are after.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">slot rotors will have better braking. because of friction. (physics)</TD></TR></TABLE>
Can you elaborate on this?
Old Nov 7, 2007 | 08:32 AM
hatch96y7's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Can you elaborate on this? </TD></TR></TABLE>
thats what i was trying to say
Motionek55
10
Sep 8, 2012 02:04 PM
EF9ZC
Mar 21, 2006 11:48 AM
JHD_DA
Aug 12, 2004 06:40 AM
patastinky
Jul 8, 2004 12:01 PM
Ozluder
Jan 26, 2004 03:24 PM
