Tach bounces...
Old Jun 23, 2002 | 11:04 AM
CimorelliCRX's Avatar
Default Tach bounces...
Okay, I have hooked up two tachs in my car, and both bounce crazy. I have a guage cluster with no tach so.. They work good up to like 4000 RPM, then it just starts bounciing around and I dont have any idea where I am at. This has happened with two tachs, any ideas? I have been told that it could have something to do with ignition timing but.. I rewired it two times to make sure everything was good and it is... Any help would be good..
Old Jun 23, 2002 | 11:09 AM
flat-blk-HB's Avatar
Default Re: Tach bounces... (CimorelliCRX)
what knid of tach are you using?
Old Jun 23, 2002 | 11:17 AM
crxzc's Avatar
Default Re: Tach bounces... (ED6)
does your check engine light go on when your tach bounces after 4000 rpm?
Old Jun 23, 2002 | 11:19 AM
keithv's Avatar
i am 99% sure your igniter is bad. change that out and it should cure the problem.
also, you can use an igniter from ANY model honda. i used one from a d16a6 in my 88 teg dist.
Old Jun 23, 2002 | 11:30 AM
bryant's Avatar
Default Re: Tach bounces... (breaka_1_9)
Yeah, I have the same problem. But mine only does it when the car is cold, or just sitting at a stop. Then it goes away. Its weird
Old Jun 23, 2002 | 11:31 AM
Would it run good though if the ignitor is bad? The car runs good... Just the tach is bouncing...
Old Jun 23, 2002 | 11:32 AM
its a sunpro tach.
Old Jun 23, 2002 | 12:00 PM
keithv's Avatar
yeah the car will run fine. mine ran a 15.5 at the track with the bouncing tach.
Old Jun 23, 2002 | 12:53 PM
customx_'s Avatar
New User
my tach would bounced once in a while but i changed the ignitor anyways.
i would also checked your vacuums.
Old Jun 23, 2002 | 01:39 PM
Default Re: Tach bounces... (mindtrix)
Can it be a loose connection or something? Its the silver thing in the distributor right? Anyway, I will mess with it tomorrow.
Old Jun 23, 2002 | 05:29 PM
therealciviczc's Avatar
Check the tach wire in the distributor. That's what it was on my GFs car. The symptoms were the same as yours.
Old Jun 23, 2002 | 06:09 PM
keithv's Avatar
yes, this is a good possibility. i should have told you to try that first. on me.
its more of a brownish color. it has some writing on it. NEC then like 5 numbers.
[Modified by breaka_1_9, 10:10 PM 6/23/2002]
Old Jun 23, 2002 | 07:43 PM
Bgladfelter's Avatar
The coil will be either brown or gray. My d16a6's is brown, ZC's is gray/silver.
The tach wire is blue off of the igniter. You'll see both of them easily once you have the cap off.
HTH
Old Jun 23, 2002 | 07:48 PM
Default Re: Tach bounces... (Bgladfelter)
Yea it may be a loose wire, because we took the ignitor out of the distributor and had autozone test it when we thought it was bad. It was good though.. So I will check connections tomorrow..
Old Jun 23, 2002 | 07:52 PM
USDM 4G VTEC's Avatar
check igniter
make sur eu got the cable on the blue one of the dist.
the sunpro has a 4/6/8 cyl check switch . make sur eu got the right one selected!!!
Old Jun 23, 2002 | 08:17 PM
Default Re: Tach bounces... (JDM EF9)
All that stuff is set right. I am gonna check first thing in the morning about the ignitor, make sure all the wires are connected to it.
Old Jun 23, 2002 | 09:20 PM
One more question, what kinda symptons do you normally have when your ignitor is going out incase it is? I have noticed for a while, that when the car revs higher it kinda bogs a little, and its been backfiring a lot lately, not just when i let off of the gas, but like at different times. Could that have something to do wtih my ignitor? Anyway, just something i forgot and got out of bed for..
lexusgui
Jul 27, 2008 07:54 PM
Dr_drache
Aug 12, 2007 05:40 PM
94hondaLS
Jun 23, 2003 10:28 PM
InjectedSS
Dec 17, 2002 10:27 PM
