removing cat
Tried a search and just need a quick answer. Does anybody have any suggestions on how to remove the cat bolts easier other than an impact gun. I tried removing the 3 bolts last night and they are rusted and will not turn. used wd-40 and still nothing, any advice?
I called them every name in the book. I just can't put my full body weight into breaking them loose because the car is only about 4 inches off the ground and it is hard to get any leverage.
[Modified by 94civicx, 8:41 PM 6/23/2002]
Try heating up the bolts and then try the impact gun, if you get lucky, you will get it off. But most of the times......nahh, never happens. i had to chop mine off with a cutting wheel and buy new bolts later on. good luck.
I just took out that whole section of exhaust piping with the cat disconnected at the headers. Then I took out the piping and cat all at once and had a friend stand on it to get it off w/ a breaker bar
[Modified by MurphDog74, 4:57 AM 6/24/2002]
slammedteg
Mar 15, 2004 04:48 PM
