Question about vibration in steering wheel...? ep3
When i drive on the freeway there is no vibration before 70 and after 80 but inbetween there is a faint cycling vibration.
I was wondering:
A) if any if you guys have or have experienced the same thing?
B)if i even need to worry about it?
C)if you guys know what it could be that would make that vibration?
thanks for any info in advance.
black ep3 2002 54xxx miles.
I was wondering:
either
A) you need an alignment
B) you need new tires (check to see if the inner walls have been eatin away) or
C) Both A and B
i had that shaking problem before and it was because my inner walls were eatin away due to no alignment.
Modified by risktypeS at 12:16 PM 11/6/2007
C) Both A and B
tire pressure and balance... check!
thanks
no suspension mods yet!<<
still deciding on what to get for suspension.. any suggestions that wont kill the bank?
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">either
C) Both A and B
Modified by risktypeS at 12:16 PM 11/6/2007</TD></TR></TABLE>
"A" is wrong ur car will never shake because ur alignment is off.....
"B" is a better answer
or
"C" check ur tires... pressure (35psi)... balance... Rims (maybe u don't remember hitting a curb or kid or somthing)
just go to a Tire shop and ask them to check out ur tires and see if u need new ones/or have a problem with one of them...
TTT
C) Both A and B
or
TTT
Shaking could also occur from camber being offset as well as all which goes into get an alignment. Also the tires should be properly balanced and aligned regardless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">Shaking could also occur from camber being offset as well as all which goes into get an alignment. </TD></TR></TABLE>
ummm no....
ummm no....
what happens when your out of alignment.. you start eating at your tires and when your tires are worn from the inside they help induce a shake. What also happens when your camber is way off? You start eating at your tires which brings us back to get an alignment more of the camber toe is what needs to be fixed.
so umm...yes. Or you can buy new tires and have them eatin away because you didn't get an alignment and start the vicious cycle again.
FBS
18
Mar 6, 2006 10:41 PM
