Wire harness off h23a1 will it fit h22a
Okay so anyone who stays tuned to my thread knows Im performing a swap. And I thank you for taking the time to read them.
I finally got out the motor and transimission, go me. Now Im up to the part of taking off the transmission and rewireing the motor.
Can the wire harness off the h23a1 plug into the h22a. Im asking this because, my harness on the h22a is hacked off at a major point. It will say me a lot of head scratching and soldering if this is so. I do know that Vtec still needs to be wired in here, So if anyone knows please let me know.
Yes it will work. If you got a JDM engine then the wire harness from it wouldn't do you any good since rhd hondas have the fuse block on the other side. You will have to use your old dizzy and coil since the jdm one has the coil in the dizzy.
killingtwobirds
May 8, 2007 12:54 PM
