larger throttle body? any TRUE dyno resluts?
Old Nov 5, 2007 | 08:44 PM
h23prelude's Avatar
Default larger throttle body? any TRUE dyno resluts?
i was thinking of purchasing a larger throttle body for my h23a1 and was curious if you guys had any input, i understand that a larger throttle will allow more air volume at a faster rate, but will a few millimeters really make a difference? i dont want to spend 250-300 dollars on something that im not going to see results from, anyone with one on a h23/h22 with a dyno sheat, or at least give me some input if it felt faster (butt dyno)
Old Nov 5, 2007 | 09:18 PM
SikB's Avatar
Default Re: larger throttle body? any TRUE dyno resluts? (h23prelude)
It would make much more of a difference if you had other mods to support it especially cams and such. Slap a 75 mm tb on a bone stock h22 and I think you would lose low end tq. Don't quote me though.
Old Nov 6, 2007 | 05:56 AM
mgags7's Avatar
search
user "jdogg" did a little test some time back.
Old Nov 6, 2007 | 09:29 AM
M2B4's Avatar
Default Re: (mgags7)
Im just finishing installing my euro r mani with 70mm tb and i have dyno time scheduled on the 17th. so if that works out i can tell you what euro r and bigger tb make...but i snapped a tranny mount stud and i cant get it out kinda weary about driving 4hrs like that. well c, but ill post up info if i go
Old Nov 6, 2007 | 10:07 AM
h23prelude's Avatar
Default Re: (M2B4)
thad be awesome if you could, good luck gettin that stud fixed, those can be a pain in the ***
Old Nov 6, 2007 | 11:41 AM
M2B4's Avatar
Default Re: (underbelly)
@ you cause i already did a baseline at the same dyno not even month ago...
Old Nov 6, 2007 | 12:57 PM
A Blue Lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underbelly &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you install your mani at the dyno? then you can do a base run first </TD></TR></TABLE>
You're retarded.
Old Nov 6, 2007 | 01:24 PM
M2B4's Avatar
Default Re: (A Blue Lude)
lol you can read my thoughts
Old Nov 6, 2007 | 03:09 PM
Cottonwoodz's Avatar
Default Re: (M2B4)
The only way to get a "true" comparison is to dyno the same day, same dyno....
wildoutwhitegsr
Mar 12, 2006 10:38 AM
zoohalee_vtec
Jan 10, 2005 08:36 PM
4505
Aug 31, 2003 12:48 PM
adotlee
Jul 11, 2003 06:16 PM
b19coupe
Jan 27, 2003 11:39 AM
