car dies after 3 mins?????
Old Nov 5, 2007 | 06:14 PM
luis31's Avatar
Default car dies after 3 mins?????
i got a 1990 accord, ex, auto. when i start it up and its cold outside, im talkin bout 50 degrees or below, 3 mins after i turn it on, it dies. i then have to wait about 5 mins of it just sitting to start up again. then it doesnt die anymore. any help?? let me kno what other info u need. thanks
Old Nov 6, 2007 | 09:05 PM
dtapia's Avatar
Default Re: car dies after 3 mins????? (luis31)
icm sounds like it is done. very common when the engine comes to temp the igniter will over heat and shut down and if you wait for a bit it wil lstart back up and start the cycle over again.
Old Nov 7, 2007 | 01:17 PM
jrlapointe's Avatar
i just bought a 94 accord and the tranny switches gears when im going 55 60 mph it has a 4 speed auto matic and it stalls when i stop fast
Old Nov 7, 2007 | 03:47 PM
luis31's Avatar
Default Re: (jrlapointe)
bump, for a really bad problem, what is the icm?
Old Nov 7, 2007 | 08:23 PM
dtapia's Avatar
Default Re: (luis31)
it is the ignition control module. also know as a igniter.
Old Nov 8, 2007 | 03:08 AM
YeuEmMaiMai's Avatar
Default Re: car dies after 3 mins????? (dtapia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia &raquo;</TD></TR><TR><TD CLASS="quote">icm sounds like it is done. very common when the engine comes to temp the igniter will over heat and shut down and if you wait for a bit it wil lstart back up and start the cycle over again.</TD></TR></TABLE>
what he said, but it could be another item as well so you need to test the ignitor to make sure that it is the problem before you start just blindly replacing stuff.
Old Dec 26, 2007 | 07:17 AM
chicows18's Avatar
Default Re: car dies after 3 mins????? (YeuEmMaiMai)
How do you go about checking if this is the case. My car (94 Accord) also does the same thing. Ill start it, then in a couple of minutes, even though Im accelerating, it just dies off. I try to restart, and it takes a couple of cranks before it will restart again.
MTapester
Apr 1, 2011 11:41 AM
maxrealtor
Mar 3, 2011 07:55 AM
playdough
Jan 5, 2008 08:55 PM
scratchlotto
Jun 6, 2005 06:36 PM
miceemic
May 16, 2005 08:05 PM
