Bouncing Tachometer needle
Old Nov 5, 2007 | 02:53 PM
Gvis420's Avatar
Default Bouncing Tachometer needle
When i start the car the tach jumps higher then tha actual rpm. Once it warms up the tach reads normal. I give it slight acceleration the tach will follow but if i give it to much fuel the needle jumps up. Ive seen alot about a ground mabey or something. I hate electricity! Im ready to install a aftermarket one. Any help?
Old Nov 7, 2007 | 09:33 AM
r1ch1e's Avatar
Default Re: Bouncing Tachometer needle (Gvis420)
check your distributor. that's what happen with me my distributor was loose.
Old Nov 7, 2007 | 10:58 AM
JustAnotherRex's Avatar
Default Re: Bouncing Tachometer needle (r1ch1e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e &raquo;</TD></TR><TR><TD CLASS="quote">check your distributor. that's what happen with me my distributor was loose.</TD></TR></TABLE>
Bad ignitor modules will cause this also.
Old Nov 7, 2007 | 11:11 AM
Gvis420's Avatar
Default Re: Bouncing Tachometer needle (JustAnotherRex)
Distributor tight! Ignitor modules? Should i just install another one and disconect this one or will it do the same thing?
Old Nov 7, 2007 | 11:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gvis420 &raquo;</TD></TR><TR><TD CLASS="quote">Distributor tight! Ignitor modules? Should i just install another one and disconect this one or will it do the same thing?</TD></TR></TABLE>
I'd try a known good distributor before replacing the ignitor, see if it solves the problem. The next step would be taking your dizzy apart and pulling the ignitor, then using a multimeter to test and see if it is good (if another distributor does make the jumpy tach stop).
s13hero
31
Jun 17, 2016 06:43 AM
totsie7944
Oct 31, 2005 11:53 AM
LilCivic04
12
Oct 13, 2005 01:29 AM
crxcess
May 5, 2005 08:35 AM
blacksheep
Oct 13, 2002 10:08 PM
