Horn wiring question
Old Nov 5, 2007 | 06:42 AM
totsie7944's Avatar
Default Horn wiring question
So I've been looking into a Sparco steering wheel with the quick release.
After talking to Sparco, they have said you cannot use the Horn anymore with the quick release. So I wanted to know how the horn wiring works...
For instance, what if I were to rig something up so that when I took off the steering wheel I just disconnected the wires from the steering wheel going into the hub adapter? Some sort of "snap on" kinda of thing?
Not knowing how the horn wiring works, I didn't know if this was even feasible. Thanks guys.
Old Nov 5, 2007 | 07:16 AM
actionanh's Avatar
i have the same question!
Old Nov 5, 2007 | 09:50 AM
totsie7944's Avatar
Default Re: (actionanh)
then it sounds like we need an answer...
Old Nov 5, 2007 | 11:03 AM
cxSHOE's Avatar
Default Re: Horn wiring question (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">
sparco sells horn buttons similar to what the mugen fg360 horn buttons look like so i think you need to talk to someone else at sparco. all i know is the negative needs to touch the steering column creating the ground for the horn button. im too lazy to figure it out.
Old Nov 5, 2007 | 11:15 AM
totsie7944's Avatar
Default Re: Horn wiring question (cxSHOE)
yea I already bought that 2 button one for the horn. I mean, the negative will touch regardless. I don't think you touch that to take the stock wheel off and put the hub adapter on. I wonder if theres a way to keep the horn buttons attached to the quick release while taking the steering wheel off....even if I had to gorilla glue it haha.
Old Nov 5, 2007 | 11:47 AM
Cheeze's Avatar
It can be done! I have a quick release and have no problem having the horn work.. You will need a crx horn shoe (or you can use the end metal piece of a pen). Run a line from the horn show to the horn wire under your dash...
https://honda-tech.com/zerothread?id=1920709
Goodluck!
Old Nov 5, 2007 | 02:33 PM
totsie7944's Avatar
Default Re: Horn wiring question (Cheeze)
thanks man...still kinda confusing since I've never taken a steering wheel off or really know what hes talking about. Hopefully it will make sense once I get it off and someone shows me which wires were for the horn.
Old Nov 5, 2007 | 04:20 PM
94rs-turbo's Avatar
and this https://honda-tech.com/zerothread?id=1887852
Old Nov 6, 2007 | 05:21 AM
totsie7944's Avatar
Default Re: (94rs-turbo)
yea I saw that thread as well...Im sure Ill figure it out. Thanks man
Ldo
May 20, 2009 09:11 PM
RVCA97
11
Feb 2, 2005 11:21 PM
Lei Siew Long
10
Aug 22, 2003 11:50 AM
