Pic Request EG CIVIC with ASR subframe brace and BLOX LCA's w/ ITR 22mm sway
Has anyone out there used this set up?? IF so...can you post up pics?
How did you get the endlinks to work?? Did you use Stock? or Aftermarket?
THanks.
THanks.
I had to use aftermarket (Blox) endlinks.
A guy had a pic posted on a EG coupe the other month with that set up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 23-10 »</TD></TR><TR><TD CLASS="quote">I had to use aftermarket (Blox) endlinks.
A guy had a pic posted on a EG coupe the other month with that set up.</TD></TR></TABLE>
Thanks for the replies......so the Blox Endlinks worked??....
Any problems thus far?? possible picture?? just want to see how the links sit with the blox lca....
thanks.
thanks.
spoon95eg
Suspension & Brakes
Apr 11, 2006 09:14 PM
