2002 Accord Brake problems
Old Nov 4, 2007 | 08:37 PM
zitro79's Avatar
Default 2002 Accord Brake problems
Hi guys,
I am having the following problem with my Accord. When I am driving at Highway speeds and I break, the car starts shaking. At lower speeds it doesn't do it. I pulled the parking brake while driving on the highway the other day and the car started shaking again, so I think it might be a problem with the rear brakes.
My car is a 2002 Accord SE 4cyl with drums in the rear.
Any help or suggestions about my problem would be appreciated.
Old Nov 4, 2007 | 08:43 PM
accordselux's Avatar
Me Gusta History
Default Re: 2002 Accord Brake problems (zitro79)
Is it speeds or just the pressure you put on the pedal that gives you that feeling?
Usually when a car shudders when you brake you have warped rotors from prolonged heavy use.
Old Nov 4, 2007 | 08:44 PM
The-Kid's Avatar
Why would you pull the e-brake at highway speeds? Drifting?
Anyways drum brakes are weak. so doing damage will be hard to do. Did you pull it hard or??? Car shake? Or steering wheel? Or both?
Old Nov 4, 2007 | 09:14 PM
pos_cd5's Avatar
Default Re: 2002 Accord Brake problems (The-Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Kid &raquo;</TD></TR><TR><TD CLASS="quote">Why would you pull the e-brake at highway speeds? Drifting?
i think its safe to assume he didnt pull it hard enough to lock the rear wheels.
Old Nov 4, 2007 | 11:39 PM
YeuEmMaiMai's Avatar
remvoe rotors and machine them if you can or replace them if you cannot
Old Nov 5, 2007 | 01:22 PM
zitro79's Avatar
Default Re: 2002 Accord Brake problems (YeuEmMaiMai)
Thanks for the answers. I'm gonna try to answer all your questions.
The shuddering comes at high speeds (highway) when you press the breaks hard. If you press them lightly, there is no vibration.
I pulled the e-brake only lightly, to try to narrow down the problem, i.e. front or rear breaks.
Old Nov 5, 2007 | 01:47 PM
accord99power's Avatar
when pressing brakes if you feel steering wheel shake its front rotors.
Old Nov 5, 2007 | 02:00 PM
Chiovnidca's Avatar
Default Re: 2002 Accord Brake problems (accord99power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Kid &raquo;</TD></TR><TR><TD CLASS="quote">Why would you pull the e-brake at highway speeds? </TD></TR></TABLE>
It's a very good diagnostic practice to help narrow down the source of a brake vibration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">when pressing brakes if you feel steering wheel shake its front rotors.</TD></TR></TABLE>
Not always. Sometimes the rears can feed back through the hydraulic system and cause the wheel to shake. It's more common with rear drums. The whole car will usually shake also.
Old Nov 5, 2007 | 02:20 PM
Default Re: 2002 Accord Brake problems (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Not always. Sometimes the rears can feed back through the hydraulic system and cause the wheel to shake. It's more common with rear drums. The whole car will usually shake also.</TD></TR></TABLE>
ahhh didnt know it was the common, thanks man!
Old Nov 5, 2007 | 05:44 PM
zitro79's Avatar
When I press the brakes the steering wheel doesnt shake at all. And again, I feel the vibration only at highway speeds when I press the brakes hard. If I press them lightly, everything is fine.
Old Nov 5, 2007 | 05:48 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zitro79 &raquo;</TD></TR><TR><TD CLASS="quote">When I press the brakes the steering wheel doesnt shake at all. And again, I feel the vibration only at highway speeds when I press the brakes hard. If I press them lightly, everything is fine.</TD></TR></TABLE>
Take a look at the rears.
Old Nov 12, 2007 | 04:34 PM
ieetgluu's Avatar
Prolly not something you can "look" and "see". But I agree with it being the rear. I would machine/replace your rear rotors/drums.
Old Nov 12, 2007 | 04:35 PM
ieetgluu's Avatar
Default Re: 2002 Accord Brake problems (ieetgluu)
Prolly wont hurt to change the pads/shoes while your at it
carguy41361
Suspension & Brakes
Oct 4, 2018 10:53 PM
sirwebbz
Mar 2, 2008 06:24 PM
eLmO_2006
Apr 14, 2007 01:41 AM
arielb1
Jul 27, 2006 09:57 PM
