Suspension & Brakes Theory, alignment, spring rates....
Suspension Noise
Old Nov 4, 2007 | 06:03 PM
TSAngry's Avatar
Default Suspension Noise
Whenever I hit a big bump on the road, there is a loud banging noise that comes from the front driver side suspension area only. Sounds like something got hit with a hammer. Anyone have similar experiences or problems?
Old Nov 4, 2007 | 06:47 PM
Targa250R's Avatar
be professional
Default Re: Suspension Noise (TSAngry)
So have you actually looked around underneath the car to see if anything is amiss? Bushings? Ball joints? Sway bar endlinks? All bolts tight?
Old Nov 4, 2007 | 08:58 PM
TSAngry's Avatar
Default Re: Suspension Noise (Targa250R)
Everything is where it's suppose to be. All bolts tight. Can't figure it out. I don't think the shock is blown either.
Old Nov 4, 2007 | 09:08 PM
1200 Hobos's Avatar
UCA is hitting shock tower, raise the car alittle.
Old Nov 5, 2007 | 12:39 PM
B16B_coupe's Avatar
HRD PKR
Default Re: Suspension Noise (1200 Hobos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1200 Hobos &raquo;</TD></TR><TR><TD CLASS="quote">UCA is hitting shock tower, raise the car alittle. </TD></TR></TABLE>
thats what it sounds like to me to, how low is your car? and check the top of your strut towers in the bay to see if they have been getting hit?!
Old Nov 5, 2007 | 03:07 PM
TSAngry's Avatar
Default Re: Suspension Noise (B16B_coupe)
It's funny because I recently raised the spring perches on my koni yellows so the car sits a little higher now. I never had this problem when it was lower. I didn't see any signs near the strut towers but I will check again.
Old Nov 7, 2007 | 04:04 AM
rm07's Avatar
as you raised your springs, the spring will be compressed a bit more. most likely the coils are hitting each other under impact.
have you tried coil wrap? or even heat shrink
Old Nov 7, 2007 | 08:07 AM
Targa250R's Avatar
be professional
Default Re: (rm07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rm07 &raquo;</TD></TR><TR><TD CLASS="quote">as you raised your springs, the spring will be compressed a bit more.</TD></TR></TABLE>
Not unless the car was resting on the bump stops previously.
What length and rate of springs are you using up front?
Old Nov 7, 2007 | 09:07 AM
TSAngry's Avatar
Default Re: (Targa250R)
I don't see signs of the UCA hitting the shock tower. I don't think it's the coils hitting each other either, because this is a really loud thud sound like a hammer hitting metal.
I'm running H&R race springs with koni yellows. I think the rate is 460lb up front.
jayare05
Mar 22, 2009 11:24 AM
christiantequila
Aug 22, 2008 09:22 AM
justininhifi
May 1, 2003 06:03 PM
1hotintegra
Dec 28, 2002 11:11 AM
