ITR front brake setup ON 95 civic coupe????????????????????
Old Nov 4, 2007 | 04:19 PM
shorsh's Avatar
Default ITR front brake setup ON 95 civic coupe????????????????????
delete
Modified by shorsh at 8:12 AM 11/5/2007
Old Nov 4, 2007 | 04:43 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: ITR front brake setup ON 95 civic coupe???????????????????? (shorsh)
it'll be fine, 96spec jdm itr brakes use 32mm also
Old Nov 4, 2007 | 04:58 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorsh &raquo;</TD></TR><TR><TD CLASS="quote">will the 96 integra type r 4x114 front brake setup fit the 95 civic coupe even if i have the original d16z6 or do I need to have bigger axles? </TD></TR></TABLE>
you will need the whole spindle, not just the caliper and brackets. and yes, if you do have the whole spindle, you can use your existing axles.
Old Nov 5, 2007 | 07:12 AM
shorsh's Avatar
thanks!!!!!
eg_h22
May 8, 2007 09:58 AM
slor209
Dec 19, 2006 03:23 AM
nurvcom..
Oct 13, 2005 07:02 PM
rice a roni
Sep 12, 2005 10:58 AM
