rear discs on a Civic Wagon
Old Nov 4, 2007 | 02:47 PM
LSVTEC96HB's Avatar
Default rear discs on a Civic Wagon
Just got done doing an LS swap/Tein susp. and Energy bushings in my '91 Wagon and was planning on installing the GSR brakes off my old 91 hatch, but I came across the Wagon's unique rear trailing arms. They use the same ones obviously for the non 4wd versions. I looked closely at it and it seems like the discs could be made to fit with some modification to the existing trailing arm. I think the only other alternative would be to relocate the lower rear subframe to use the GSR trailing arms. Has anyone attempted the trailing arm modification? I hate drum brakes.
Old Nov 7, 2007 | 10:13 PM
crexer's Avatar
Default Re: rear discs on a Civic Wagon (LSVTEC96HB)
i wanna know to. picking up a wagon tomorrow
Old Nov 7, 2007 | 11:38 PM
~sp33~'s Avatar
EFB055
I wouldnt mind being in for answers.
Old Nov 9, 2007 | 05:01 PM
shuttle xer's Avatar
Default Re: (~sp33~)
RT4wd rear trailing arms are different. do you have a 4wd? I have rear disk brakes for a wagon with the appropriate e brake cables for sale. 500 shipped.
this was my last project.
Old Nov 9, 2007 | 05:18 PM
rear disks i quoted above are for 2wd
Old Nov 9, 2007 | 05:36 PM
LSVTEC96HB's Avatar
Default Re: (shuttle xer)
Am I to understand that the RT wagon has discs? Mine is a '91 2wd. The trailing arms are different than standard civic. The rear LCA is pushed further back to allow room for the axle shaft on the RT. The lower rear subframe is totally different also. I think the existing trailing arms could possibly be modified to accept the disc hubs. Has anyone tried this? I am not going to pay $500 for used stock rear discs
Old Nov 9, 2007 | 07:45 PM
nihad's Avatar
wow nice *** shuttle
Old Nov 10, 2007 | 09:06 AM
Default Re: (LSVTEC96HB)
you think 500 is bad for parts, labor and shipping?
Old Nov 10, 2007 | 09:07 AM
nah the RT doesnt have disks. just the trailing arm is a bit different.
Old Nov 11, 2007 | 06:27 PM
LSVTEC96HB's Avatar
[QUOTE=shuttle xer]RT4wd rear trailing arms are different. do you have a 4wd? I have rear disk brakes for a wagon with the appropriate e brake cables for sale. 500 shipped.
QUOTE]
What wagon came with rear discs then? Since you have a set.
Old Nov 11, 2007 | 06:36 PM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shuttle xer &raquo;</TD></TR><TR><TD CLASS="quote">you think 500 is bad for parts, labor and shipping?</TD></TR></TABLE>
what do you mean labor? Are you going to go over to the persons house and install them?
Old Nov 11, 2007 | 06:40 PM
Tremek's Avatar
He probably made them. No wagons came with rear discs from the factory as far as I know.
Old Nov 11, 2007 | 07:18 PM
LSVTEC96HB's Avatar
Default Re: (Tremek)
Back to my original question then. Has anyone done the trailing arm modification I described? I don't really want to be the guinea pig here. I'm on a budget of $0 and a 5 gallon bucket of elbow grease.
Old Nov 11, 2007 | 07:39 PM
Do not relocate your subframe.
Old Nov 11, 2007 | 07:42 PM
Default Re: (Zaakro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC96HB &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=shuttle xer]RT4wd rear trailing arms are different. do you have a 4wd? I have rear disk brakes for a wagon with the appropriate e brake cables for sale. 500 shipped.
QUOTE]
What wagon came with rear discs then? Since you have a set.</TD></TR></TABLE>
No they have to be made
Old Nov 11, 2007 | 07:45 PM
JOEY F.'s Avatar
Not really an answer but a source...
I remember a couple of years ago it was either Honda Tuning or Super Street that had a project Wagon and they acutally used the rear disc components from another car and fit it on the existing wagon trailing arm. Im sure you can order back issues from their sites... It was pretty detailed and involved a press and some parts swapping but came out really clean.
Old Nov 11, 2007 | 07:53 PM
1989CivicSi's Avatar
Default Re: (JOEY F.)
Yes.
If the op knows anything about cutting/welding he can make them for about $100-150$ in parts max. If he doesn't, he can have them made for 200$ in parts and labor max. If he has the parts already sitting around, it's free.
$500 can buy you a complete 4x114.3 ITR setup.
Old Nov 11, 2007 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOEY F. &raquo;</TD></TR><TR><TD CLASS="quote">Not really an answer but a source...
I remember a couple of years ago it was either Honda Tuning or Super Street that had a project Wagon and they acutally used the rear disc components from another car and fit it on the existing wagon trailing arm. Im sure you can order back issues from their sites... It was pretty detailed and involved a press and some parts swapping but came out really clean. </TD></TR></TABLE>
They used a bracket to convert from drum do disk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
Yes.
$500 can buy you a complete 4x114.3 ITR setup. </TD></TR></TABLE>
Like you said "If" and where'd you pull those numbers from? yea he could get 4x114 setup for that but then he'd have to do the same to those. That setup is from a DC2 and his car needs something from EF/DA to bolt up andsit right.
I pmed him 400 shipped with brake cables.
Old Nov 13, 2007 | 05:40 PM
oldskool88291's Avatar
hey if ne1 is selling a rt 4wd wagon let me no, i cant 1 newhere and i really want 1 bad. i got a zc motor im gonna put into it
Old Nov 13, 2007 | 07:35 PM
Default Re: (oldskool88291)
$50 for RTA's + Blown rear calipers + figure in resurfacing fee + new remanned calipers w/core charge + other misc crap you may need along the way comes out to 150-200 in parts. Current RTA's w/drums are free. Maybe another 50 in labor, but if highly doubtful.
Not to flame, but if you honestly spent $500+ (what you were asking for your otherwise stock rear disk setup) on the brakes and are trying to sell them for $500+, you really need to find a better source for parts/a shop that won't rip you off on labor (I.E. 300+ to measure, cut, and weld RTA's).
$500.00 + right now will get you a JDM EF9 frontend in decent shape off the boat in San Diego if you know the right sources, and quite literally "shipped."
Old Nov 13, 2007 | 11:13 PM
justseeingifitistaken's Avatar
Default Re: (1989CivicSi)
i think the real problem here is you may not understand the rt4wd issue.....brake lines/e brake cables from ANY other model do not work because of the angle of the LCA and trailing arm and other issues...they have to be custom fabbed. I have an rt4wd and have compared side by side to see for myself. i would rather pay 500 for shuttle xer (whch has done this a few times...check out hondacivicwagon.com sometime) then to have some one 'fab them up' for 150 not know WTF they are really getting themselves into/doing at all...and pay for new brakes again in the end or worse...your life?? actually when you think about it...keep it stock and less risk entirely
Old Nov 16, 2007 | 04:01 PM
Default Re: (justseeingifitistaken)
Thank you /\. He doesnt have a RT but whatever. and im not asking 500+ Its 500 shipped. Has anyone ever tried shipping something heavy and long?
Old Nov 16, 2007 | 07:41 PM
4doorsleepr's Avatar
holy ****, got rice??
way to ruin a perfectly good EF, retard
Old Nov 16, 2007 | 10:34 PM
Default Re: (4doorsleepr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorsleepr &raquo;</TD></TR><TR><TD CLASS="quote">
way to ruin a perfectly good EF, retard</TD></TR></TABLE>
how is ti ruined??? try PERFECT...the wings are the only thing not to my liking, but overall clean.
Old Nov 27, 2007 | 08:09 PM
LSVTEC96HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justseeingifitistaken &raquo;</TD></TR><TR><TD CLASS="quote">
how is ti ruined??? try PERFECT...the wings are the only thing not to my liking, but overall clean.</TD></TR></TABLE>
it is kind of ricey.
