Help - what is this component? its leaking..
Old Nov 4, 2007 | 01:18 PM
JasonA's Avatar
Default Help - what is this component? its leaking..
Hi all,
Can anyone tell me what this component is inside my 1990 5 speed Prelude? Its leaking a clear oil like fluid (although its definitely not the Motor oil). what does it take to fix this fluid leak?
thanks for any advice!
(oh you'll notice a vacuum port capped off - I had my coolant hoses replaced and the mechanic forgot what it was connected to so he just capped it - since then the leaking problems began.)
Old Nov 4, 2007 | 01:32 PM
Acidcrakker's Avatar
Default Re: Help - what is this component? its leaking.. (JasonA)
I think thats your transimmisson. I forget what it called though. Check your transsmission fluid levels.
Old Nov 4, 2007 | 01:39 PM
marks_lude's Avatar
Default Re: Help - what is this component? its leaking.. (Acidcrakker)
thats not a vacuum port... its the breather for the tranny. i wouldnt cap it.
Old Nov 4, 2007 | 01:47 PM
JasonA's Avatar
ok, I'll remove the rubber cap - thanks!!
exactly what part of my transmission is this? Now that its started to leak, will it have to be replaced?
Old Nov 4, 2007 | 02:05 PM
Hawkze_2.3's Avatar
Default Re: (JasonA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonA &raquo;</TD></TR><TR><TD CLASS="quote">ok, I'll remove the rubber cap - thanks!!
It looks like you're talking about the cover that sits on top of the tranny to cover up some arms and connections inside. Mine is slowly leaking too
Upper left:
Old Nov 4, 2007 | 03:33 PM
Dangger's Avatar
clean it off with break cleanner really nice... then watch for the leak again.. it's prolly some stupid gasket that you can replace.
david420
Sep 9, 2010 06:48 PM
SonicRacing
Jul 27, 2008 08:07 AM
whiteboy03si
Mar 7, 2007 08:03 PM
vabchaccord
Jan 13, 2004 11:10 PM
civicmon
10
Nov 17, 2003 03:54 PM
