Gurus help. Quick question on 97 Accord non vtec. Timing belt problems.
If the timing belt and/or balance shaft belt breaks on one of these engines, does this engine suffer from valve damage or not?
Not <U>always</U> causes bent valves. It is possible.
You can check for bent valves; get the old belt off turn the crank 90 degrees from TDC, that puts the pistons 1/2 way up. pull the valve cover off. then rotate the cam, so that you close the valves at each cylinder. with the spark plugs out you can use a tight fitting hose in the spark plug hole and blow thru it to listen for air escaping thru the intake or exhaust, while that cylinders valves are closed.
Thanks for this reply.
URLs below are dead.
"Not Found
The requested URL /hondadude/ was not found on this server."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">....</TD></TR></TABLE>
Year and model Helps get better info
webpages for those needing help
http://members.troublecodes.ne...a.htm
http://members.troublecodes.ne...R.htm
http://members.troublecodes.ne...r.htm
http://members.troublecodes.ne...s.htm
http://members.troublecodes.net/hondadude/vtec.jpg
"Not Found
yeah sorry about the links; I'm a poor person right now, when I get rich I'll pay some bills, then get some FOOD.
