Still confused about B18B1 swap
Old Nov 4, 2007 | 10:56 AM
scuzz's Avatar
Default Still confused about B18B1 swap
I've read all the FAQs about the swap. I can't find out, or missed one issue I have. Do I have to use the B18B1 trans, or will the engine bolt to my stock 88 CRX DX trans?
I was getting ready to just find a Z6 engine, harness, ECU, but I can get this B18B1, with anything I want to take off car for 150.00. I know that having access to the whole car will make it a lot easier. The motor is in a 92 hatchback now.
I don't want a drag car, just a better running street car than the DPFI, that gets decent mileage.
Thanks,
Ron
Old Nov 4, 2007 | 11:15 AM
crxsleeper210's Avatar
You Can use any b-series tranny or in this case your b18b1 tranny. Your stock tranny (sohc) will not bolt on/work at all with the b18.
Default Re: (crxsleeper210)
also is it cable or are you converting to hydrolic?
Old Nov 4, 2007 | 11:34 AM
socalrex88's Avatar
Default Re: Still confused about B18B1 swap (scuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsleeper210 &raquo;</TD></TR><TR><TD CLASS="quote">You Can use any b-series tranny or in this case your b18b1 tranny. Your stock tranny (sohc) will not bolt on/work at all with the b18. </TD></TR></TABLE>
really true! use your b18b tranny i think they are hydro...but get the cable to hydro converter from hasport.... i suggest getting a b16 tranny!
Old Nov 4, 2007 | 02:09 PM
scuzz's Avatar
Default Re: Still confused about B18B1 swap (socalrex88)
I'm going to have to go back and see donor car again. I didn't notice what trans was in it. I just assumed the 92 trans was still there.
What's the easiest way to tell what trans they used?
I ran the serial numbers on the car, and it came back as a 1500 cc engine originally, but that's all I remember.
Is there a place online that I can check the number again. My buddy at the junk yard ran it for me on his in house system.
I'll learn this pretty quick. I built Chevy hotrods most of my life, except for a 18 year run with VW and Porsche cars in 70's and 80's.
I'm 60 now, but I'm having a ball with this little CRX. It reminds me of the VW cars I built big engines for.
Thanks,
Ron
Modified by scuzz at 3:26 PM 11/4/2007
chicklet
Transmission & Drivetrain
Aug 20, 2016 10:19 PM
da_rimrocka
Apr 19, 2006 11:37 PM
robs93civic
Mar 30, 2006 05:48 PM
juan08086
Sep 21, 2005 09:21 AM
pro547
Aug 2, 2004 08:49 PM
