Suspension & Brakes Theory, alignment, spring rates....
TOKICO ILLUMINAS TOTALLY WORTH THE $500!!!
Old Nov 4, 2007 | 08:57 AM
civic_saints1's Avatar
Default TOKICO ILLUMINAS TOTALLY WORTH THE $500!!!
THESE SHOCKS ARE OFF THE HOOK!!!! RECOMMEND THEM TO ANYONE!!
Old Nov 4, 2007 | 12:04 PM
turnsignalandy's Avatar
Default Re: TOKICO ILLUMINAS TOTALLY WORTH THE $500!!! (civic_saints1)
what springs you using?
Old Nov 5, 2007 | 04:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
$500 for Illuminas? dang you got ripped on that deal.
You can get Koni Sport shocks for less than $500, which are even better than Illuminas.
Old Nov 5, 2007 | 06:42 AM
EK_B's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">$500 for Illuminas? dang you got ripped on that deal.
You can get Koni Sport shocks for less than $500, which are even better than Illuminas.</TD></TR></TABLE>
+1
$500 for Illuminas are way too much.
Old Nov 5, 2007 | 08:37 AM
JustAnotherRex's Avatar
I know I've seen $460 shipped with a lifetime limited warranty.
Ah well, the mistakes we make along the way are part of the learning process.
This same process tends to destroy your pocketbook sometimes, but I'm glad you're happy with your purchase.
Old Nov 5, 2007 | 10:02 AM
Emerica's Avatar
I got my Koni Yellows for 450 shipped but my buddy runs illuminas and they arent bad. but hey, whatever you like!
Old Nov 5, 2007 | 10:35 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">You can get Koni Sport shocks for less than $500, which are even better than Illuminas.</TD></TR></TABLE>
[opinion]
i wouldnt call yellows "better" than illuminas. i think illuminas are better for most ppl here looking to upgrade their shocks. but yellows certainly are more expensive than illuminas. the biggest advantage koni has is that they are rebuildable and revalveable. none of which is cheap and only adds on to the cost of the shock. and they really need to be revalved for real competitive use since the compression isnt adjustable. whereas illuminas adjust both compression and rebound and i have personally found more useable on both the street and track for a wide variety of springs and purposes.
[/opinion]
OP, did you pay $500 for the shock and spring combo? or just the shocks? do you live outside of the US?
Old Nov 5, 2007 | 10:55 AM
Community Builder
Default Re: (Tyson)
Doesn't look like the Illuminas adjust compression damping at all in front, and barely in on the rear:
Front shocks:
Rear shocks:
I just like the Konis better because they're infinitely adjustable (if you count 1/4 turns, that's 8 positions available for a total of 1 3/4 turns), and also for the height adjustable options available.
Old Nov 5, 2007 | 11:18 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't look like the Illuminas adjust compression damping at all in front, and barely in on the rear:</TD></TR></TABLE>
the fact is that they do. ive shown they do as thats my graph of the rear shock. that front graph is from koni's website sales slideshow. i havent had a chance to dyno the fronts myself, but from what i heard from OTHER independent sources who have dyno'd tokicos, they in fact DO. infer from that whatever you want.
as for "barely", compression is always at a lower value than rebound. that graph reflects that. ive heard a rule of thumb is 1:3 ratio. focus your attention at the lowspeed part of the graph as thats the real performance area anyway. youll see that its hardly insignificant as the descriptive word "barely" would imply.
konis dont.
really, not making a pissing match, "fanboy" argument or whatever. ive clearly stated whats my opinion, whats fact, and whats conjecture.
Old Nov 6, 2007 | 07:00 PM
95vxtealhatch's Avatar
I Just installed illuminas and i love the adjustability. I live around very rough roads, so i set my struts 1 front and 1 rear. Its rides just like stock and is so comforable. When im on smoother portions of the city i can up the front 3 and rear to 2. Im on stock springs too btw. I bought mine for $365 shipped
Old Nov 6, 2007 | 07:01 PM
Default Re: (95vxtealhatch)
how is the handling comapred to stock on the stiffer settings?
taylor1
Jul 17, 2008 07:24 AM
EricMichael
Jan 11, 2004 11:24 AM
BumpinVTEC
Aug 26, 2003 08:12 PM
Rhythm Racer
10
Jun 5, 2003 08:02 PM
no2unenolife
May 8, 2003 01:10 PM
