98 Hatch: tranny swap, clutch release folk SPRING! how it should sit PICS!
Old Nov 3, 2007 | 06:18 PM
polything's Avatar
Default 98 Hatch: tranny swap, clutch release folk SPRING! how it should sit PICS!
the tranny is sitting outside, i dont know how the little SPRING should sit.
Old Nov 3, 2007 | 06:20 PM
polything's Avatar
another question, when i put the release bearing in place, it kinda LOOSE, big time, i can see the gap, like 1/2 cm. is it right?
Old Nov 3, 2007 | 06:21 PM
nabin's Avatar
Default Re: 98 Hatch: tranny swap, clutch release folk SPRING! how it should sit PICS! (polything)
im pretty sure that the tip of that spring should be in that hole that is it by. possible flipped over from the pic
Old Nov 3, 2007 | 06:22 PM
nabin's Avatar
Default Re: 98 Hatch: tranny swap, clutch release folk SPRING! how it should sit PICS! (nabin)
a gap on what? between the fork and the throw out?
Old Nov 3, 2007 | 06:26 PM
1992Si's Avatar
first off, to much grease.
The ball end of the pin goes between the spring wire and the fork.
You need to put the bearing on the fork then install the assembly on the pin and over the shaft at the same time.
Second, to much grease.
Old Nov 3, 2007 | 07:04 PM
polything's Avatar
Default Re: (1992Si)
will clean up the grease.
the gap between the bearing and shaft.
i tried to install everything without the spring, its works.
when the spring comes in, it does not do anything.
the position of the spring in the pic is correct right?
what pin are you talking about?
Old Nov 4, 2007 | 12:38 PM
polything's Avatar
anyone?
Old Nov 4, 2007 | 03:00 PM
jwerks's Avatar
Default Re: (polything)
LOL FRIST OFF YOU HAVE THAT SPRING IN THE WRONG WAY, FLIP IT AND TRY AGAIN KEEP UP POSTED
Old Nov 4, 2007 | 03:09 PM
1992Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polything &raquo;</TD></TR><TR><TD CLASS="quote">will clean up the grease.
what pin are you talking about?</TD></TR></TABLE>
The spring slides over the ball headed pin that is to the left of the input shaft in the photo. It has the red grease on it. The spring goes into the grove below the ball on the pin.
The spring is not backwards, I just checked our spare trannys in the shed. Both have the spring the same way your's is.
The only difference I see is your spring is not positioned correctly in the slots on your fork. put that top left side into the slot .
The bottom of the spring needs to go through the slot in the bottom of the fork also. fix that
The spring does follow the recess in the fork.
Modified by 1992Si at 7:19 PM 11/4/2007
Modified by 1992Si at 7:20 PM 11/4/2007
Modified by 1992Si at 7:22 PM 11/4/2007
Old Nov 4, 2007 | 07:23 PM
polything's Avatar
i will try to bend the spring tomorrow!
Old Nov 4, 2007 | 11:56 PM
nabin's Avatar
DONT BEND THE SPRING!!
the end of the spring should fit in that hole in the fork! i dont know if its backwards or not, but i know for sure that the end of it is suppoesed to be in that hole
Old Nov 5, 2007 | 04:34 AM
polything's Avatar
that's wat i thought too!
i flipped it but it does not fit in. i have to bend it. it doesnt snug in nicely
Old Nov 5, 2007 | 04:46 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">
The spring does follow the recess in the fork.</TD></TR></TABLE>
This is correct make sure once you slide everything on and that the spring locks into the grove on the back of the pivotball. Once in place you should be able to push the fork forvard and see the spring catch in the grove. Trust me no this you want that thing locked in the right way. There is no worse feeling then getting the whole car back together stepping on the clutch felling a pop and having no clutch. I lost both the slave and the master cylinder on top of having to pull the trans back out of the car to put the forkk back in place. It took a 3 hour job and made it into a 10 hour one.Good luck
Old Nov 5, 2007 | 09:47 AM
polything's Avatar
Thank you for the head sup!
Old Nov 8, 2007 | 08:58 AM
polything's Avatar
so i tried to bend the spring. it still does not sit right. I turned the spring around, and it snug right in. !!!! it s completely backward from the first picture, OEM honda factory manual illustration (they just have the illustration, no how to)
werd....
In the process, i fucked up the brand new Autozone brand Slave cylinder :??!! Made in Taiwan crap
Old Nov 11, 2007 | 12:42 PM
jwerks's Avatar
Modified by 1992Si at 7:22 PM 11/4/2007</TD></TR></TABLE>
LIKE i SAID BACKWARDS LOL
Old Nov 11, 2007 | 03:07 PM
eggmygirl's Avatar
* B A N N E D *
From: Running Round At Night In Los Angeles Like A Crazy, Veva Mexco, Veva Mexco
you little greasy monkey
I8ayellowcrayon
Aug 13, 2008 08:17 PM
MINT90EF
Jun 24, 2005 11:32 AM
XzzYzzX
Mar 5, 2005 08:45 AM
Cjsls
Mar 16, 2004 08:02 PM
therealciviczc
Apr 9, 2002 03:19 PM
