"B" type-S pistons in "A" bore h22a block
Old Nov 3, 2007 | 05:16 PM
SP GARAGE's Avatar
Default "B" type-S pistons in "A" bore h22a block
well to make it short i got brand new type-S pistons and i have a h22 "A" bore block. now my question is will it work. this is going to be a 87x95 with h23 crank and rods with type-S pistons. i wanna make sure this will work before i start this build.
Old Nov 4, 2007 | 05:51 AM
my9thtry's Avatar
Default Re: "B" type-S pistons in "A" bore h22a block (FLATBUSH PROJECTS)
You port and poilsih heads for a living and you cant answer this question yourself?
Old Nov 4, 2007 | 06:58 AM
SP GARAGE's Avatar
i do not port heads. i have someone who does and can get you prices. but thanx for answering my question
Old Nov 4, 2007 | 09:20 AM
InvaderTrax's Avatar
I'm not exactly sure what you're asking. Do you mean A vs B stamped pistons? Because there's a .01mm size difference. Measure the pistons and the bore and see if they're in spec
Old Nov 4, 2007 | 08:04 PM
my9thtry's Avatar
Default Re: (FLATBUSH PROJECTS)
just get over-sized pistons and re hone the cylinders when fresh hone for a new motor would help...
VSBB6
May 16, 2006 09:09 AM
VSBB6
speedyonez
Jun 28, 2005 11:20 PM
delacampos
Dec 2, 2004 01:26 PM
MyVtec8yourV8
Aug 29, 2004 10:34 AM
