anyone use a GM IAT sensor?
just wondering who uses a GM IAT sensor? i know it has alot quicker response than hondas IAT sensor which is very slow.
i would be keeping it in my new intake manifold like hondata reccommends..
http://store.summitracing.com/...-2320
or
http://www.diyautotune.com/cat....html
or
The Honda one doesn't really respond that slowly. That is more or less a myth. The problem is that it is mounted on the intake manifold. Because of this, the heat from the heat soaked intake manifold effects how the much temperature change the IAT sees. If you mount it on the charge pipe you will see the Honda IAT sensor being much more effective.
https://honda-tech.com/zerothre...28255
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothre...28255</TD></TR></TABLE>
very informative.
with that said, should i make a flange to put my honda IAT in my charge pipe, or get a gm and thread that into my charge pipe?
running s300?
very informative.
running s300?
Get the gm I am running one with my ems also and I just tapped the pipe and threaded it in.I am not familiar with hondata but if it has the scaling capabilities for the iat then use it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype »</TD></TR><TR><TD CLASS="quote">The Honda one doesn't really respond that slowly. That is more or less a myth. The problem is that it is mounted on the intake manifold. Because of this, the heat from the heat soaked intake manifold effects how the much temperature change the IAT sees. If you mount it on the charge pipe you will see the Honda IAT sensor being much more effective.
ask tony about his expierence with the response time of the gm vs. honda. its unbelievable
with obd1 ecu's hondata recommends leaving the IAT in the intake manifold. that and i dont feel like changing my tune up by placing it in the charge pipe.
i dont know about it being a myth, but when im datalogging in s300 it hardly ever changes and we all know that in boosted app's the iats are constantly changing..dramatically and quickly sometimes.
i dont see any kind of rescaling for the iat in s300. it shouldnt matter any, both the gm and honda iat are both the same type of sensor. correct me if im wrong. i forget the word for the type of sensor it is.
tony, you have any feedback?
btw if anyone wants a aluminum 3/8th NPT bung to weld on to the intake manifold or charge pipe for the gm sensor you can get it on summit, they have about 50 different ones to choose from..
http://store.summitracing.com/...20072
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">i maybe be dumb to ask but where is the stock IAT located on the stock mani? is it that one that mounts one of the intake runners??</TD></TR></TABLE>
depends on which stock manifold youre talking about.
its white with two phillips screws holding it on.
I simply mounted the sensor in my charge pipe by first heating the pipe cherry red and then I hammered a small section flat so it would mount flush. I then drilled a hole in the center for the sensor and used self tapping screws to bolt it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets »</TD></TR><TR><TD CLASS="quote">I'm curious, too. Bump.</TD></TR></TABLE>
a picture to bring more views
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">on an LS. how would you go abt moving it to the charge pipe. is there any type of flange you can buy to weld it on or do you just have to figure it out some how.</TD></TR></TABLE>
You get a bung for the charge pipe (just like an O2 but smaller; same idea)
Make sure if your going to use the GM sensor, it has to screw in... I dont know the part number but if you order one for a Buick Grand National, it should be the screw in style like pictured above
we use gm temp sensors on our cars. mounted in the charge pipe
we have seen charge temps of 250 degrees (non intercooled)
we used an aluminum NPT weld bung to mount it.
For those who need part #'s
GM IAT Sensor #25036751
GM IAT Sensor Pigtail #12102620
You can find them here. Shipping is overprised so be prepared.
http://www.diyautotune.com sells them as well almost everyone that runs megasquirt uses the gm sensors
I'm definitely going to do this. I'd use a Honda sensor, but the fact that these thread in is nice.
I have 4 3/8" NPT weld bungs that I was going to use for a catch can project, but will only be using 1 for this. So, I have 3 left over that I have no use for. If anybody wants one, just pay me a couple of bucks for shipping. I won't be using them anyway, so you guys can have them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisbmx68 »</TD></TR><TR><TD CLASS="quote">http://www.diyautotune.com sells them as well almost everyone that runs megasquirt uses the gm sensors </TD></TR></TABLE>
According to the site they are"GM-style sensors". Not sure what to take from that. The MSD ones are only 15$ on summit. I spent the 50 shipped for one from GMPARTSDIRECT. You can also ****** one up at the dealer fro close to that price I'm sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets »</TD></TR><TR><TD CLASS="quote">I have 4 3/8" NPT weld bungs that I was going to use for a catch can project, but will only be using 1 for this. So, I have 3 left over that I have no use for. If anybody wants one, just pay me a couple of bucks for shipping.</TD></TR></TABLE>
OOOOO Are the aluminum? I want one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .dave »</TD></TR><TR><TD CLASS="quote">I have a GM IAT sensor mounted in my charge piping, running on Neptune.</TD></TR></TABLE>
so your using one on a honda ecu ??
so far i havent fouind anyone thats using one on a honda ecu.. are the caliberatiosn the same between the gm and honda sensors? any one ever done any testing to find out?
