rebuilding rack.
Old Nov 3, 2007 | 01:16 PM
makavali27's Avatar
Modified by makavali27 at 10:21 AM 12/9/2007
Old Nov 3, 2007 | 08:46 PM
makavali27's Avatar
Default Re: rebuilding rack. (makavali27)
What i really wanted to know is that having 220,000 miles, will the pinion and steering rack be worn out? those two items alone would cost 150.
number 7 and 9.
Old Nov 5, 2007 | 03:15 AM
b18LS's Avatar
Probably not worn out, but might have some play in it. I'd first install new bushings and tie rods, if they're needed. Also, if you follow your steering coloumn to the firewall inside the car, theres a rubber boot you can pull aside to access where you coloumn attaches to your steering gear. Theres a 10mm bolt that can loosen up over time in there, a couple of quick turns and it can really tighten things up. Try the little things first, before spending the bucks! If the rack is out, you should be able to inspect it, and buy the parts as needed.
Old Nov 5, 2007 | 05:30 AM
makavali27's Avatar
Default Re: rebuilding rack. (b18LS)
How do people feel about ebay tie rods?
http://cgi.ebay.com/ebaymotors...sting
Or just stick with oem? for $150
ra64
Sep 15, 2014 06:48 PM
90ED6LSV
Apr 6, 2013 12:53 PM
furiousbob
Mar 13, 2009 02:26 AM
EZ$$EF
Jan 7, 2008 04:07 PM
sloweh3
May 1, 2004 12:26 PM
